Bootloader ,Using SRecCvt-GUI to convert S19 file ,No output??
1,554 次查看
ChenBowen
I just want to use the SRecCvt-GUI to convert the Project.abs.s19 file for CAN-BootLoader(xs128) using.But when I do like the follow
Why no output?  Why the Debug mode says "Can't Open Input File "?
1 回复
1,536 次查看
lama
I am not able to test it because of your folder structure. However, what I suggest is to copy the original S19 file into the SRecCvt folder and convert it there. It is better to use "no path" access to avoid any problems with tree structure.
Ladislav
