S12XEP100 PORTA7 problem
1,631 次查看
dashuangshengds
S12XEP100  GPIO output is not follow the software control.
        I use PORTA7 as output. After my ECU power on, I  set the GPIO is high and the pin voltage is high. When the ECU run few hours, the PORTA7 pin voltage is 0V, not  high level.
        So I check the PORTA register, the DDR and DATA is follow the design and not changed during the running.
        I want to know, is there any other cause for this problem?  Thank you!
标记 (1)
1,548 次查看
lama
you do not describe port connections (load) and entire setup. Pin is open drain after reset.
Only brief suggestion, PUCR_PUPAE=1;
Ladislav
1,548 次查看
dashuangshengds
Hi, thank you reply!
