使用multilink fx时经常出现“Error during flash programming.Terminating debug session”
zgk20072002
dianabatrlova
Which development environment do you use?
I have found one case, someone had the same error and this procedure helped: PEmicro Blog
Can you share the screen of debug configuration window?
Also, the reinstall IDE can help.
Thank you.
Diana
