S12XDP512 CAN transmit error counter
1,858件の閲覧回数
jtpark
I have a question.
I used S12XDP512 for CAN communication.
When CAN transmit error occurs,how increase TX error counter?
If transmit error occurred, is error counter increasing one bit? or more bits?
I can't check it in reference manual.
would you please let me know this issue?
Thanks.
1,705件の閲覧回数
lama
the CAN module meets CAN2.0AB standard.
The specification can be found in the https://www.nxp.com/files/microcontrollers/doc/data_sheet/BCANPSV2.pdf
See chapter 12.2 Error counts. The error counters works automatically. You can only do something on error interrupts.
If this does not answer your question do not hesitate to reply.
Ladislav
1,705件の閲覧回数
jtpark
Dear lama,
Thanks for your reply.
JT Park
1,706件の閲覧回数
lama
Ladislav
