S12DG128 - simulate Flash and EEPROM failure
1,434 次查看
gavryus
I need to implement a test program which simulate FLASH and/or EEPROM failures at startup and durring runtime.
Can somebody give a hint how to do this?
Is there an application note or a demo application which can give me an idea?
1000 x Thank you!
Regards!
679 次查看
Alban
Senior Contributor II
Apart from actually damaging the device or changing the software to make it check a value that does not exist, I don't see any solution.
Alban.
