Request for MC9S12XDG128 Flash Driver Example Code
gl123
Junior Contributor I
Dear NXP Support Team,
I am currently developing an application using the MC9S12XDG128 (S12XDG family) MCU.
I need official Flash driver example code / driver example project for:
  • Flash erase, program, read operations
Could you please provide:
  1. Official Flash driver example (C code / CodeWarrior project)
  2. Related application notes or reference code for Flash programming on S12XDG
  3. Any driver libraries or example for in-application Flash programming
Thank you for your help.
lei.gao
lama
there is no official driver.
However, attached is an example from my drawer for the device with larger Memory. I believe you will be able to port it because the only change is memory size.
Ladislav
%3CLINGO-SUB%20id%3D%22lingo-sub-2348120%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERequest%20for%20MC9S12XDG128%20Flash%20Driver%20Example%20Code%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2348120%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CDIV%3EDear%20NXP%20Support%20Team%2C%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EI%20am%20currently%20developing%20an%20application%20using%20the%20%3CSTRONG%3EMC9S12XDG128%3C%2FSTRONG%3E%20(S12XDG%20family)%20MCU.%3CDIV%3E%26nbsp%3B%3C%2FDIV%3EI%20need%20%3CSTRONG%3Eofficial%20Flash%20driver%20example%20code%20%2F%20driver%20example%20project%3C%2FSTRONG%3E%20for%3A%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CUL%3E%3CLI%3EFlash%20erase%2C%20program%2C%20read%20operations%3C%2FLI%3E%3C%2FUL%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3ECould%20you%20please%20provide%3A%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3COL%3E%3CLI%3EOfficial%20Flash%20driver%20example%20(C%20code%20%2F%20CodeWarrior%20project)%3C%2FLI%3E%3CLI%3ERelated%20application%20notes%20or%20reference%20code%20for%20Flash%20programming%20on%20S12XDG%3C%2FLI%3E%3CLI%3EAny%20driver%20libraries%20or%20example%20for%20in-application%20Flash%20programming%3C%2FLI%3E%3C%2FOL%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EThank%20you%20for%20your%20help.%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EBest%20regards%2C%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Elei.gao%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2349941%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Request%20for%20MC9S12XDG128%20Flash%20Driver%20Example%20Code%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2349941%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%0A%3CP%3Ethere%20is%20no%20official%20driver.%26nbsp%3B%3C%2FP%3E%0A%3CP%3EHowever%2C%20attached%20is%20an%20example%20from%20my%20drawer%20for%20the%20device%20with%20larger%20Memory.%20I%20believe%20you%20will%20be%20able%20to%20port%20it%20because%20the%20only%20change%20is%20memory%20size.%3C%2FP%3E%0A%3CP%3EBest%20regards%2C%3C%2FP%3E%0A%3CP%3ELadislav%3C%2FP%3E%3C%2FLINGO-BODY%3E
