Bit field
Bit field
Aswin_5232
I am using MC9S12DG256 controller and IDE is CodeWarrior 5.2. When I am disabling the option bit field size reduction , the memory allocation starts from mid instead of start. for example my variable is of type int it starts from 8 instead of 0. I want to start from 0. Please find the screen shot attached.
lama
the game you are playing is related to the defined sizes of bitfield elements (unsigned char, unsigned int) and then MSB. LSB order, MSb, LSb order. I suggest you to test combinations simply with different options after reading the help ....
If you want more info about bitfields I suggest to go through all appearnces in
Plus when you select an item it can show more options with the same name. Open each of them because each of them direct to different contet.
... or go to your instalation dir c:\Program Files (x86)\Freescale\CWS12v5.2\Help\pdf\
open file Compiler_HC12.pdf
and search for each existence of bitfield keyword.
Ladislav
