RAM Segment Error Messgage.
2,542 次查看
rayhall
I am getting this error message..
Link Error : L1102: Out of allocation space in segment RAM at address 0x2466
The help tells me to...
Set the end address of the specified segment to an higher value.
How and where do I do this.
Ray.
2,314 次查看
kef
Specialist I
Your ecu struct needs almost 10k of RAM. This won't fit nonpaged RAM, which is only 8k. You may extent your nonbanked RAM up to 12k like suggested here
https://community.freescale.com/message/334635#334635
4 回复数
2,314 次查看
ZhangJennie
Link Error : L1102 means “The specified segment is not big enough to contain all objects from the sections placed in it”. please check the prm file, if you can allocate more RAM memory to the RAM object. if you can't solve the problem, please upload the project here. we will check.
2,313 次查看
rayhall
Jun,
I have supplied the project in zip file.
Ray.
2,315 次查看
kef
Specialist I
2,313 次查看
rayhall
Edward,
Thank you. That worked..
Ray.
