One shunt Sensorless  BLDC control
1,986件の閲覧回数
ahnjoseph
Can do s12zvl Sensorless BLDC controlcontrol with One shunt ?
If it can do How can use nxp LIB ?
1,802件の閲覧回数
RadekS
Hi Ahn,
Unfortunately s12zvl is not directly designed for driving BLDC motor.
You will probably need external FET driver. Please look at hardware solution for older S12G family:
http://www.nxp.com/products/software-and-tools/run-time-software/automotive-software-and-tools/motor...
Or you could choose one of s12zvm family derivatives with gate drive unit module and drive BLDC motor directly. For more details, please look at:
I hope it helps you.
RadekS
1,802件の閲覧回数
ahnjoseph
Thanks your kindly mention of my question
I know s12zvl is
not directly Motor control it must be with FET or IGBT
So, My question is
using just one shunt for FOC-sensorless BLDC MOTOR control with NXP LiB
Normally, Sensorless
control is using with 3-shuts or 2-shunts
Can s12zvl control Sensorless
BLDC motor with just one-shunt?
