One shunt Sensorless  BLDC control
1,985 次查看
ahnjoseph
Can do s12zvl Sensorless BLDC controlcontrol with One shunt ?
If it can do How can use nxp LIB ?
1,801 次查看
RadekS
Hi Ahn,
Unfortunately s12zvl is not directly designed for driving BLDC motor.
You will probably need external FET driver. Please look at hardware solution for older S12G family:
http://www.nxp.com/products/software-and-tools/run-time-software/automotive-software-and-tools/motor...
Or you could choose one of s12zvm family derivatives with gate drive unit module and drive BLDC motor directly. For more details, please look at:
I hope it helps you.
RadekS
1,801 次查看
ahnjoseph
Thanks your kindly mention of my question
I know s12zvl is
not directly Motor control it must be with FET or IGBT
So, My question is
using just one shunt for FOC-sensorless BLDC MOTOR control with NXP LiB
Normally, Sensorless
control is using with 3-shuts or 2-shunts
Can s12zvl control Sensorless
BLDC motor with just one-shunt?
