MC9S12ZVC transmission error
2,756 次查看
jhChoi
I set MC9S12ZVC as a slave. The signals and frames from the master product come from my MCU, but I can't send them from MCU to the master. What should I do to make a slave in my product line?
2,744 次查看
danielmartynek
Please specify the interface, is it SPI, I2C, LIN?
Thank you,
BR, Daniel
2,739 次查看
jhChoi
Hello.
LIN is used in my project.
thank you.
2,732 次查看
chaitanya_kalyani
Hello @jhChoi ,
You need to call l_u8_wr_ macros to write the data that you can get in lin_cfg.h file according to your LDF.
I have attached LIN User Manual. Check page no 53 you will get the sample program it might help for you.
The same document you can get in your location  C:\NXP\LIN_stack_S12_4_6_3\Documentation if you installed LIN stack.
