MC9S12ZVC transmission error
2,771件の閲覧回数
jhChoi
I set MC9S12ZVC as a slave. The signals and frames from the master product come from my MCU, but I can't send them from MCU to the master. What should I do to make a slave in my product line?
3 返答(返信)
2,759件の閲覧回数
danielmartynek
Please specify the interface, is it SPI, I2C, LIN?
Thank you,
BR, Daniel
2,754件の閲覧回数
jhChoi
Hello.
LIN is used in my project.
thank you.
2,747件の閲覧回数
chaitanya_kalyani
Hello @jhChoi ,
You need to call l_u8_wr_ macros to write the data that you can get in lin_cfg.h file according to your LDF.
I have attached LIN User Manual. Check page no 53 you will get the sample program it might help for you.
The same document you can get in your location  C:\NXP\LIN_stack_S12_4_6_3\Documentation if you installed LIN stack.
