Internal temperature sensor MM9Z1J638
Boris_Bloxsberg
I`ve got some questions regarding the internal temperature sensor.
Is there a detailed description of the regsiters  B_COMP_ITO, B_COMP_ITG, B_COMP_ETG avialable (e.g. Calculation)?
Are the trim values induvidual calculated for every MCU?
StanoA
Hello Boris,
The all about system calibration and how to use the calibration values stored in FLASH for each chip is in AN12301:
https://www.nxp.com/docs/en/application-note/AN12301.pdf
I hope it could help you solve your task.
Stano.
Boris_Bloxsberg
thx.
StanoA
Hello Boris,
Stano.
