ISR(Cap1_Interrupt)
ISR(Cap1_Interrupt)
kdn
How can i use ISR(Cap1_Interrupt) interrupt in my code. I am using processor expert.
kdn
I write my code in user define function, but not working
ZhangJennie
Hi KDN,
I suggest you refer demo code under
C:\Freescale\CWS12V5_1\ProcessorExpert\Projects\Test projects\Capture
Zhang Jun
this answer is for you. if it helps, please click on "Correct Answer " button. Thanks!
