How to use Rappid bootloader with S12ZVML-MINIBRD kit ?
1,889 次查看
Maciek
Contributor V
I've flashed S12ZVM.rbf file into the board. When I'm trying download my application using Rappid PC-side application - I get the following error message: 'CCP Communication Error. Loss Communicatin with CCP MCU. Please cycle power and try again." Of course cycling power doesn't help...
How to slove this problem ?
Does this (S12ZVM.rbf) Rappid bootloader work with UART1 (which is accessible via USB on this board) ?
Maciek
标记 (2)
1,618 次查看
fengwang
Hello Maciek,
How did you solved this error , I have the trouble like you ! Can you help me ?
many thanks
Feng
1,618 次查看
iggi
here is a webpage that gives Overview of RAppID Bootloader. You can launch a live presentation video or just open a presentation document.
Overview of RAppID Bootloader|NXP
Btw, please ensure the USB-to-SCI (UART port) operates correctly.
Check on your PC in Device and Printers if you see as below:
and Device Manager:
Hope this helps.
iggi
