How to measure the frequency?
1,541 次查看
aaronlee
Contributor V
We are using S12ZVCA(LQFP-48) and CodeWarrior 11.0 for measure the frequency of external signal. The frequency is between 1Hz and 500Hz.
Which pin do you recommend to connect the external signal?
Do you have example code?
Aaron
标记 (2)
1,419 次查看
aaronlee
Contributor V
Dear Daniel,
Thanks for your reply. We are design the schematic for PCB as following:
The PT4 & PT7 for frequency input. Do you have any recommend?
Aaron
1,419 次查看
danielmartynek
Hello Aaron,
This is application-dependent, there is no recommendation,
BR, Daniel
1,419 次查看
danielmartynek
Please refer to this example:
https://community.nxp.com/docs/DOC-332554
BR, Daniel
