How to Calculate Chip Temperature for 9s12vr?
1,072 次查看
dli1
I wanted to read the chip temperature for a 9s12vr chip using its internal ADC channels.  I was able to read the ADC counts for the chip temperature and bandgap, but did not know how to convert it to temperature in degree C.  Unable to find the specification for the conversion.  Appreciate if anyone can post the conversion formula.
914 次查看
RadekS
Hi David,
The temperature sensor has to be calibrated for giving enough accurate results. The offset and slope are specific for every MCU. The selected calibration method depends on required accuracy.
Please look at our application note AN3624 S12X Temperature Sensor
http://www.nxp.com/files/microcontrollers/doc/app_note/AN3624.pdf
Some more general details about calibration may be found also in our application note AN3031 Temperature Sensor for the HCS08 Microcontroller Family
http://www.nxp.com/files/microcontrollers/doc/app_note/AN3031.pdf
I hope it helps you.
RadekS
