Flexray Frames Configuration
Kartoon67
I'm working with the Freescale Development Card EVB9S12XF512E. For making an communication between two flexray nodes, it needs to configuration the network.
In fact, there is a function which did that in freescale example :
/* Structure of this type contains configuration   information of the one low level parameters set */const Fr_low_level_config_type Fr_low_level_cfg_set_00 ={    ..........    5000,       /* G_MACRO_PER_CYCLE */    10,         /* G_MAX_WITHOUT_CLOCK_CORRECTION_PASSIVE */    14,         /* G_MAX_WITHOUT_CLOCK_CORRECTION_FATAL */    22,         /* G_NUMBER_OF_MINISLOTS */    60,         /* G_NUMBER_OF_STATIC_SLOTS */    4920,       /* G_OFFSET_CORRECTION_START */    16,         /* G_PAYLOAD_LENGTH_STATIC */    ..........}
 I would like to know if I'm understanding well something.
The argument G_PAYLOAD_LENGTH_STATIC represent the duration of a static frame, that right?
In my example, the argument is put at 16. That mean I can send at maximum 16 byte of data in my Flexray frames?
Thanks you in advance for your answers, because i really need to know if am right to continu my project.
bobgardner
The payload length is in words I think. 16 words=32 bytes.
juunna
Me too!!!!!!!!!
can you tell me how to deal with it?
%3CLINGO-SUB%20id%3D%22lingo-sub-169199%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EFlexray%20Frames%20Configuration%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-169199%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EI'm%20working%20with%20the%20Freescale%20Development%20Card%20EVB9S12XF512E.%20For%20making%20an%20communication%20between%20two%20flexray%20nodes%2C%20it%20needs%20to%20configuration%20the%20network.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EIn%20fact%2C%20there%20is%20a%20function%20which%20did%20that%20in%20freescale%20example%20%3A%3C%2FP%3E%3CPRE%3E%2F*%20Structure%20of%20this%20type%20contains%20configuration%26nbsp%3B%26nbsp%3B%20information%20of%20the%20one%20low%20level%20parameters%20set%20*%2Fconst%20Fr_low_level_config_type%20Fr_low_level_cfg_set_00%20%3D%7B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20..........%26nbsp%3B%26nbsp%3B%26nbsp%3B%205000%2C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F*%20G_MACRO_PER_CYCLE%20*%2F%26nbsp%3B%26nbsp%3B%26nbsp%3B%2010%2C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F*%20G_MAX_WITHOUT_CLOCK_CORRECTION_PASSIVE%20*%2F%26nbsp%3B%26nbsp%3B%26nbsp%3B%2014%2C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F*%20G_MAX_WITHOUT_CLOCK_CORRECTION_FATAL%20*%2F%26nbsp%3B%26nbsp%3B%26nbsp%3B%2022%2C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F*%20G_NUMBER_OF_MINISLOTS%20*%2F%26nbsp%3B%26nbsp%3B%26nbsp%3B%2060%2C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F*%20G_NUMBER_OF_STATIC_SLOTS%20*%2F%26nbsp%3B%26nbsp%3B%26nbsp%3B%204920%2C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F*%20G_OFFSET_CORRECTION_START%20*%2F%26nbsp%3B%26nbsp%3B%26nbsp%3B%2016%2C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F*%20G_PAYLOAD_LENGTH_STATIC%20*%2F%26nbsp%3B%26nbsp%3B%26nbsp%3B%20..........%7D%3C%2FPRE%3E%3CP%3E%26nbsp%3BI%20would%20like%20to%20know%20if%20I'm%20understanding%20well%20something.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EThe%20argument%20G_PAYLOAD_LENGTH_STATIC%20represent%20the%20duration%20of%20a%20static%20frame%2C%20that%20right%3F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EIn%20my%20example%2C%20the%20argument%20is%20put%20at%2016.%20That%20mean%20I%20can%20send%20at%20maximum%2016%20byte%20of%20data%20in%20my%20Flexray%20frames%3F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EThanks%20you%20in%20advance%20for%20your%20answers%2C%20because%20i%20really%20need%20to%20know%20if%20am%20right%20to%20continu%20my%20project.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3ERegards%2C%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-169199%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EGeneral%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2164986%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Flexray%20Frames%20Configuration%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2164986%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMe%20too!!!!!!!!!%3CBR%20%2F%3Ecan%20you%20tell%20me%20how%20to%20deal%20with%20it%3F%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-169200%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Flexray%20Frames%20Configuration%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-169200%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThe%20payload%20length%20is%20in%20words%20I%20think.%2016%20words%3D32%20bytes.%20%3C%2FP%3E%3C%2FLINGO-BODY%3E
