Download hex file to MC9S12CLF
3,421件の閲覧回数
paulung
I want to download a hex file to MC9S12G96CLF. Can I use the MULTILINK UNIVERSAL programmer and CodeWarrior software to do that? If I can't, what are my options? I think PROG12Z will do the job but I would like to test it before buying it.
Many thanks.
Paul.
6 返答(返信)
3,115件の閲覧回数
aaronlee
I use the MULTILINK UNIVERSAL programmer and CodeWarrior to flash my code to S12ZVC. I think MULTILINK UNIVERSAL support S12G, too.
I use 6-pin BDM connect to MULTILINK UNIVERSAL.
3,115件の閲覧回数
paulung
I couldn't find way to do that. Could you give me some instructions? I am using CodeWarrior v5.1. Thanks.
Sent from my iPhone
3,115件の閲覧回数
danielmartynek
You should be able to use CW 5.1 / 5.2 and Multilink Universal.
What exactly is the problem? Do you use a development board?
3,115件の閲覧回数
paulung
We have codes and I can compile that codes using CW 5.1 and download it to the S12 micro on our board using multilink universal. It runs perfectly.
Now I want to send just the hex file (.s19), no code, to a customer so he can download the hex file to the board. How can this be done using CW 5.1 and multilink universal? Could you give me a brief instruction?
Thanks.
Sent from my iPhone
3,115件の閲覧回数
danielmartynek
You can download the S19 file which is generated by CW5.1 (project/bin/.abs) to MCU using hiwave.exe,
Go to the root folder of the CW5.1 /Prog/hiwave.exe
Set up connection via Multilink and then Load your S19 file.
3,115件の閲覧回数
paulung
Thanks Daniel.
Sent from my iPhone
