Does S9ZVL12MLF chip have can interface?
2,924 次查看
nujia
I am using the DEVKIT-S12ZVL.      I downloaded the example from NXP.com .  The example is ZVL32MLF, and works ok.     The part ID is 0x04150000.     But the picture is S9ZVL12MLF.
So  is S9ZVL12MLF  ZVL32MLF or ZVLA12MLF?
The difference between the two chips is that one consists of CAN and the other does not have CAN.
Thanks.
2,865 次查看
danielmartynek
Hello @nujia,
Thank you for the information.
I see, either the ID register or the label is incorrect.
I can't explained it, I'm sorry for all the inconvenience.
You can read SRAM at 0x1400 which is unimplemented on S12ZVL32.
If Machine exception rises, the part is S12ZVL32
Regarding the download link, thank you for pointing it out, let me report it.
4 回复数
2,903 次查看
nujia
Thank you, Daniel martynek,
I think the S9ZVL12MLF is ZVL32MLF.    So I plan to buy s9zvl128mlf development board.
But there is a wrong code download link.
2,866 次查看
danielmartynek
Hello @nujia,
2,812 次查看
nujia
Hi , Daniel,
         Thank you,   It runs to the Machine exception ISR.  So it is S12ZVL32.
2,911 次查看
danielmartynek
Hello @nujia,
Can you show a screenshot of the ID register in the memory view?
BR, Daniel
