Difference between S912ZVLA64F0CLFR and S912ZVL64F0CLFR.
Edgar_Jiang
hi
Could you help me to find the difference between S912ZVLA64F0CLFR and S912ZVL64F0CLFR.My client want to order  S912ZVLA64F0CLFR.But we only have S912ZVL64F0CLFR.If S912ZVLA64F0CLFR could be replace by S912ZVL64F0CLFR? If not,what's the difference between them?
lama
They are directly replaceable. The have also the same mask set and errata list. The only difference is that ZVLA has defined, tested a and guaranteed also Analog Comparator Module (ACMP) and Programmable Gain Amplifier (PGA).
If you use these modules at ZVLA then they are not allowed to be used on ZVL device. If you use them then quality is not guaranteed and you loss warranty.
Ladislav
lama
Ladislav
