Derivative could not be unsecured
1,732 次查看
liuweiwei
mc9s12xdp512.  I want to unsecure the mcu, but it failed everytime. But other mcu can be unsecured. Can you tell me is there some way to unsecure or is it broken?
1,469 次查看
RadekS
Hi Liu,
Additionally please check whether MCU is correctly powered and gated (XCLKS pin,…).
Please check also BDM cable orientation…
Please touch MCU by finger. When MCU is hot, it is probably damaged...
I hope it helps you.
Radek
1,469 次查看
danielmartynek
You can unsecure the MCU in CW debugger mode
HCS12MultilinkCyclonePro -> Unsecure
If this doesn’t work, you can use PEmicro Unsecure12 utility.
