Debugger Undetected Disconnect / Connect USB cable
2,505 次查看
houzongbin
    I debugged 9S12XHY256 device prototype with a  P&E tool, I can select USB Multilink in CW 5.1 when debug , and it shows 'Port:  Undetected . Disconnect/Connect USB cable.'
The development environment as follows:
         Window 10 64 bit
         Code warrior 5.1
I don't how to solve this problem. So can you help me solve the question?  thanks!
2,502 次查看
dianabatrlova
Code Warrior 5.1 is not supported by Win 10. You can use older Windows (7 and lower version) or you can install Code Warrior 5.2:
https://www.nxp.com/design/software/development-software/codewarrior-development-tools/codewarrior-l...
But S12XHY is not supported by CW 5.2. However, you can import this device by following the instruction on this link:
https://community.nxp.com/t5/Classic-Legacy-CodeWarrior/How-to-Add-missing-derivatives-to-CodeWarrio...
I hope it helps.
Diana
2,492 次查看
houzongbin
Hi dianab
Thank you for your help ,I have solved the question through you help.
2,503 次查看
dianabatrlova
I hope it helps.
Diana
