DSP56F800 - USB interface JTAG programmers
4,104 次查看
Devendra
We are currently using Parallel port (25-pin) to JTAG (10-pin) interface for programming DSP56F800 and MC56F8300 series controllers.
I would like to know if there is any USB interfaced JTAG programmer, because modern day Laptops don't have a parallel port.
Any converter for USB to Parallel port should work for this? There are some converters available which emulate a parallel port through a coverter hardware and some device driver installed in the PC.
Please reply ASAP.
Thanks and Best Regards,
Devendra
Alban Edit: Please always include FSL Part Number in Message Subject line.
http://forums.freescale.com/freescale/board/message?board.id=FORUMUSE&message.id=865
Message Edited by Alban on 2007-10-15 02:23 PM
1,803 次查看
Cowboy
1,803 次查看
Cowboy
Hi Devendra
Here are some sites that you can order from.
I havend tested one of these, but I'm pretty sure they will work
