In order to start dev of a new ECU Project, I am using Codewarrior, but unfortunately the MCU choosed is not supported "MC9S12ZVMAL3VLF"
Is there anyway to add it to my IDE and also have a SDK + LIN Slave Stack already existing that needs only configuration to fit my project needs?
Solved! Go to Solution.
 RadekS
			RadekS
		Hello SLAK,
It is a bit hard to answer here.
The LIN tack for S12Z isn't production-ready software according to our terminology (SPICE level B at least). On another side, it isn't pure example software.
We have LIN conformance test certificate, provided by a third party (C&S).
So, you may use it in production and expect some quality level, however, it is without a standard quality pack and warranty.
Anyway, many customers are using it in production already.
We have Test pass rate = 100%
RadekS
 RadekS
			RadekS
		Hello SLAK,
The MC9S12ZVMAL3V part number isn't in the system and does not fit with standard nomenclature.
I expect some typo error in the part number.
Are you looking for :
Did you try to update your installation of the Codewarrior?
Unfortunately, we do not offer any SDK for S12Z devices.
The LIN stack is available at https://www.nxp.com/webapp/swlicensing/sso/downloadSoftware.sp?catid=SW-LIN2X-J2602-D
For a fresh start, you may use the Processor Expert tool for code generation and easy prototyping.
Or, you may look at some technical example code S12(X) and S12 MagniV - available Examples and Documents
If you target motor control applications, you may start directly with some motor control kit/board:
I hope it helps you.
RadekS
Hi Radek,
Thanks for your answer.
You are right it was about ZVMAL32.
And thanks for LIN stack link, Is this Stack qualified for a use in serial production projects or it is just for Prototyping ?
 RadekS
			RadekS
		Hello SLAK,
RadekS
Thanks Radek for clear information.
Can you add a link to this conformance test report please?
