CW communication with 9S12XDP512
2,866 次查看
roberthiebert
Senior Contributor I
I have just installed a Special Edition of CW, IDE V5.9.0 build 5294. I would like to use the AD9S12XDP512M2 development board from Technological Arts and use CW to program in assembler. I am not clear on what additional hardware I will require to communicate with the board and load the .s19 file.
Do I have any options here?
2,692 次查看
ZhangJennie
P&E also has some other pod can support HCS12(X). you can see details in the related webpage:
Cyclone PRO
http://www.pemicro.com/products/product_viewDetails.cfm?product_id=1
USB Multilink Universal
http://www.pemicro.com/products/product_viewDetails.cfm?product_id=15320137
USB Multilink Universal FX
http://www.pemicro.com/products/product_viewDetails.cfm?product_id=15320143
they are more expensive than P&E BDM multilink.  P&E BDM multilink is most popular used emulator for HCS12(x) family.
this answer is for you. if it answers your question, please click on the "correct answer" button.
JunZhang
6 回复数
2,692 次查看
ZhangJennie
hi Robert,
the recommend program pod for this board is P&E BDM multilink. see this link: http://www.pemicro.com/products/product_viewDetails.cfm?product_id=33
if you have any question on this, please contact again.
JunZhang
2,692 次查看
roberthiebert
Do I have to purchase any software to use the P&E BDM multilink?
2,692 次查看
ZhangJennie
No, no software needed to use P&E BDM Multilink.
JunZhang
2,692 次查看
roberthiebert
That's good news. Do I have any options other than the P&E BDM multilink?
2,693 次查看
ZhangJennie
Cyclone PRO
JunZhang
2,692 次查看
roberthiebert
Thanks again
