Assembly code porting from GCC to CodeWarrior
2,665 次查看
embitel
Please let me know how to port the below code from GCC to CodeWarrior. This whole code is embedded in C code.
 __asm__ __volatile__ (
            "ldd   #512\n"
            "tthclr:\n"
            "movw   #0, 2,y+\n"
            "dbne   d, tthclr\n"
            : "y"(ram_data)
            : "d");
The problem is with the last three lines of code.
            : "y"(ram_data)
            : "d");
Thank you,
Deepak
4 回复数
2,421 次查看
MJW
Hello Deepak,
from looking at the code I don't see a real reason to write this in assembly language; I would just re-write this loop in C.
But if you are looking for an easy way to have the exact same code in Codewarrior, this should do:
asm {        ldy  #ram_data        ldd  #512tthclr:        movw #0,2,y+        dbne d,tthclr}
HTH,
MJW
2,421 次查看
embitel
Hello MJW,
Thanks for the solution. I have one doubt. What is the meaning of  "d" in the last line of code.
            : "y"(ram_data)
            : "d"
Deepak
2,421 次查看
MJW
Hello Deepak,
If I remember correctly, the last line tells gcc that the register "d" was changed ("clobbered") in the inline assembly portion.
HTH,
MJW
2,421 次查看
embitel
Hello MJW,
How can we replicate that same behaviour of "d" in CodeWarrior? As I am just porting, I would like to have all the code.
Deepak
