About the LDF/NPF of LIN
4,292 次查看
guofeng
Hi!
Is there some documents to introduce the content of LDF/NPF? I don't know how to edit these files.
标记 (1)
3,660 次查看
danielmartynek
10 回复数
3,661 次查看
danielmartynek
You may refer to AN5122 Using NXP’s LIN Driver with the MagniV Family.
3,660 次查看
guofeng
Hi Daniel,
    Thank you for your  reply.
    I have another question.  According to the LIN_User_Manual introduced, the MM912F634 can not  support Master mode, which confuse me. What is the difference between Master device and Slaver device?
3,660 次查看
danielmartynek
Can you post a link to the LIN_User_manual?
The difference is described in the LIN specification.
3,660 次查看
guofeng
Hi Daniel,
    I am sorry that I didn't find the link to LIN_User_manual.
    I installed FSL_LIN_2.X_STACK. The LIN_User_Manual stored in the "'Documentation" folder.
    This is the screenshot from the LIN_User_Manual.
3,660 次查看
danielmartynek
Sorry for the late response, I'm still investigate the issue.
Could you tell me the exact part number of your device?
Thank you,
3,660 次查看
guofeng
Hi Daniel,
   My device is the MM912F634.
   Guofeng Lai
3,660 次查看
danielmartynek
Please provide full part number.
3,660 次查看
guofeng
    The part number is MM912F634CV1AE(935318526557).
     I'm using the KIT912F634EVME Evaluation Board.
Guofeng Lai
3,660 次查看
danielmartynek
Thanks for the part number.
Unfortunately, the master mode hasn't been tested on the device.
Do you want to use the device as LIN master?
3,660 次查看
guofeng
   I want to test the LIN. But I only have two KIT912F634EVME.
   I was curious that why the KIT912F634EVME can be slave, can not be master.
