Hi!
Is there some documents to introduce the content of LDF/NPF? I don't know how to edit these files.
解決済! 解決策の投稿を見る。
Hi Daniel,
Thank you for your reply.
I have another question. According to the LIN_User_Manual introduced, the MM912F634 can not support Master mode, which confuse me. What is the difference between Master device and Slaver device?
Can you post a link to the LIN_User_manual?
The difference is described in the LIN specification.
Hi Daniel,
I am sorry that I didn't find the link to LIN_User_manual.
I installed FSL_LIN_2.X_STACK. The LIN_User_Manual stored in the "'Documentation" folder.
This is the screenshot from the LIN_User_Manual.
Sorry for the late response, I'm still investigate the issue.
Could you tell me the exact part number of your device?
Thank you,
Hi Daniel,
My device is the MM912F634.
Guofeng Lai
Please provide full part number.
The part number is MM912F634CV1AE(935318526557).
I'm using the KIT912F634EVME Evaluation Board.
Guofeng Lai
Thanks for the part number.
Unfortunately, the master mode hasn't been tested on the device.
Do you want to use the device as LIN master?
I want to test the LIN. But I only have two KIT912F634EVME.
I was curious that why the KIT912F634EVME can be slave, can not be master.
