9S12X assembly instruction clarification
3,452 次查看
roberthiebert
Senior Contributor I
I have some assembly code written for the 9S12X that I am trying to figure out what it does. One instruction is:
ADDD 8,SP   I believe that is and instruction to add the contents of Accu D with the contents at stack +8.
Another instruction is :
ADDD (8+2),SP  Is that the same as ADDD 10,SP which would be an instruction to add the contents of Accu D with the contents at stack +10?
Robert
3,397 次查看
danielmartynek
Hi Robert,
So, (8+2) is an offset to location M which is the SP in this case
M = 0x6E, M+1 = 0x88 which is added to D (A = 0x00, B=0x00).
D = 0x6E88
4 回复数
3,414 次查看
danielmartynek
Hello Robert,
I'm sorry for the delay.
It is explained in the CPU12X reference manual v01.04.
It concatenates the content of M with the content of M+1 and adds it to the accumulator D.
I believe you can test it in CW 5.2, there is a simulator if you don't have any board.
3,408 次查看
roberthiebert
Hi Daniel,
Thanks for your response. Yes, I had looked up the ADDD instruction as you posted, and it makes sense when ADDD is followed by a memory location, but I am still confused as to what (8+2),SP means. I'm afraid that any manipulations on the stack confuse me easily.
Robert
3,390 次查看
roberthiebert
Hi Daniel,
Got it, and thanks so much for the lesson in debugging. So it looks like I was correct in my original post where I thought that (8+2),SP could be the same as 10,SP. I wonder why the author would chose to do it that way?
Robert
3,398 次查看
danielmartynek
Hi Robert,
D = 0x6E88
