Rapid Iot Studio Display Issues.
3,457 次查看
attari
hope you all are fine. i am developing my program in rapid iot studio to display sensors data saperatly such as we see in Rapid IoT Weather Station Example but when i develop my example it will move to next screen but with in a second it come back to home screen. can any body help me how i can fix this Display Issue ?Screen Shot 2019-02-14 at 8.46.53 PM.png
3,244 次查看
richard_laborde
You have "Touch Data Read" set to return to the Root page.
So every time a touch is read, it will return to the root page.
If you remove the Ability for that one, it should navigate Right when you touch Right, and go to Root when you touch Top.
4 回复数
3,244 次查看
attari
Thanks Richard. now it's work.
3,244 次查看
richard_laborde
muhammadimranafzal‌ - it seems most likely that the trigger on your touch element is not set correctly. Can you share those settings? Or your .atmo file. Thanks
3,244 次查看
attari
please look at attach file. thanks for assisting me.
3,245 次查看
richard_laborde
