Bluetooth provisioning problems
1,956 次查看
vassily98
Provisioning of my Rapit IoT kit keeps failing with my Android Phone most of the times providing this label: "Unable to authenticate device's hardware credentials". The phone is the only device connected to the IoT.
标记 (2)
1,723 次查看
estephania_mart
By any chance, have you tried this process?
Rapid IoT kit not booting?
Also, did you modified something in software through any of the IDE's? If you did, what did you modified when before the device entered this state?
Estephania
1,723 次查看
vassily98
I have partially solved the problem. The software had nothing wrong and after more 2-3 rebooting of both the phone and the IoT i was able to connect.
Note: when you reflash Rapid IoT always remove the device from the app before flashing! Otherwise it would be hard time to try to reconnect again.
1,723 次查看
estephania_mart
It's good that it works now if you face it again let me know.
