LS1043A - Secure boot from QSPI
1,855 次查看
jeremy_sauget
I am using an LS1043A based board and I am trying to use secure booting from QPSI. As I am facing some issues, I did some research but I did not find any example or previous post saying it as already been done successfully.
Does anyone already did it ?
Thanks in advance for your help.
1,727 次查看
ufedor
Secure boot from QSPI is supported for the LS1043A.
It is possible to use LS1046ARDB QSPI secure boot as example.
1,728 次查看
jeremy_sauget
Hi ufedor,
Thanks for your answer. I already had a look on LS1046A example but I was interested in having a ready to go example to test on my LS1043A board to see if I can make it work before applying it to my specific case.
1,728 次查看
ufedor
There is no such example for the LS1043A because the LS1043ARDB lacks a SPI flash connected to the QSPI interface.
