LS1043A Ethernet Additional Issue!
Gyosun
I am using LS1043A custom board.
SDK is QORIQ-SDK-2.0-1703.
Previously, Ethernet was used well as follows.
SRDS_PRTCL_S1_RCW[128:143]: 1460
SerdesA - XFI - Retimer - 10G SFP+
Reset Configuration Word (RCW):
00000000: 08100010 0a000000 00000000 00000000
00000010: 14600002 80004012 60040000 c1002000
00000020: 00000000 00000000 00000000 0002e806
00000030: 00000000 001e1308 00000096 00000001
We needed additional 1G Ethernet, so we changed the existing 10G slot to 1G.
SRDS_PRTCL_S1_RCW[128:143]: 3460
SerdesA - SGMII - PHY - RJ45
I changed RCW from 1460 to 3460 and tried to boot,
but even u-boot doesn't show any logs.
Do I need to change the fsl_fman_ucode_ls1043_r1.1_108_4_9.bin file?
If I need to change it, how can I do it without the source code?
Or do you know what else is wrong?
Thank you,
Gyosun.
Gyosun
I solved it myself and share it for help.
I set up dts like this:
arch/arm64/boot/dts/freescale/fsl-ls1043a.dtsi
fman0_10g_rx0: port@90000 {
  cell-index = <0>;
  compatible = "fsl,fman-port-10g-rx";
  reg = <0x90000 0x1000>;
fman0_10g_tx0: port@b0000 {
  cell-index = <0>;
  compatible = "fsl,fman-port-10g-tx";
  reg = <0xb0000 0x1000>;
  fsl,qman-channel-id = <0x800>;
fm1mac9: ethernet@f0000 {
  cell-index = <0>;
  compatible = "fsl,fman-memac";
  reg = <0xf0000 0x1000>;
  fsl,port-handles = <&fman0_10g_rx0 &fman0_10g_tx0>;
arch/arm64/boot/dts/freescale/fsl-ls1043a-rdb.dts
&fman0 {
  ethernet@e4000 {
    phy-handle = <&rgmii_phy1>;
    phy-connection-type = "rgmii";
  ethernet@e6000 {
    phy-handle = <&rgmii_phy2>;
  ethernet@f0000 {
    phy-handle = <&sgmii_phy1>;
    phy-connection-type = "sgmii";
  mdio@fc000 {
    rgmii_phy1: ethernet-phy@0 {
      reg = <0x0>;
    rgmii_phy2: ethernet-phy@1 {
      reg = <0x1>;
    sgmii_phy1: ethernet-phy@3 {
      reg = <0x3>;
When changing from xfi to sgmii, you need to change SD1_REF_CLK from 156MHz to 125MHz.
I reset the phy address in uboot and dts.
Gyosun
Somehow the log was printed.
It was recognized as follows in u-boot.
=> mdio list
FSL_MDIO0:
0 - AR8035 <--> FM1@DTSEC6
1 - AR8035 <--> FM1@DTSEC4
3 - AR8031/AR8033 <--> FM1@DTSEC9
FM_TGEC_MDIO:
=> mii info
PHY 0x00: OUI = 0x1374, Model = 0x07, Rev = 0x02, 1000baseX, HDX
PHY 0x01: OUI = 0x1374, Model = 0x07, Rev = 0x02, 1000baseX, HDX
PHY 0x03: OUI = 0x1374, Model = 0x07, Rev = 0x04, 1000baseX, FDX
After booting,
CASE1:
The dts file is set up as follows:
fman0: fman@1a00000 {
fman0_rx8: port@90000 {
cell-index = <8>;
compatible = "fsl,fman-port-1g-rx";
fman0_tx8: port@b0000 {
cell-index = <8>;
compatible = "fsl,fman-port-1g-tx";
cell-index = <8>;
fsl,port-handles = <&fman0_rx8 &fman0_tx8>;
&fman0 {
ethernet@e4000 {
status = "okay";
ethernet@e6000 {
status = "okay";
ethernet@f0000 {
status = "okay";
mdio@fc000 {
rgmii_phy1: ethernet-phy@1 {
reg = <0x1>;
rgmii_phy2: ethernet-phy@2 {
reg = <0x2>;
reg = <0x3>;
I checked with ifconfig -a and fm1-mac9 is not visible at all.
root@ls1043ardb:~# ifconfig -a
fm1-mac3  Link encap:Ethernet  HWaddr fc:c2:3d:31:76:54
          BROADCAST MULTICAST  MTU:1500  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
          Memory:1ae4000-1ae4fff
fm1-mac4  Link encap:Ethernet  HWaddr 00:04:9f:04:4d:e2
          Memory:1ae6000-1ae6fff
root@ls1043ardb:~# dmesg | grep fm1
[    4.458930] fsl_dpa fsl,dpaa:ethernet@2 fm1-mac3: renamed from eth0
[    4.519680] udevd[1353]: renamed network interface eth0 to fm1-mac3
[    4.526057] fsl_dpa fsl,dpaa:ethernet@3 fm1-mac4: renamed from eth1
[    4.669416] udevd[1354]: renamed network interface eth1 to fm1-mac4
root@ls1043ardb:~# uname -a
Linux ls1043ardb 4.1.35-rt41 #16 SMP Tue Nov 8 19:14:01 KST 2022 aarch64 GNU/Linux
CASE2:
cell-index = <0>;
cell-index = <0>;
cell-index = <0>;
&fman0 {
ethernet@e4000 {
status = "okay";
ethernet@e6000 {
status = "okay";
ethernet@f0000 {
fixed-link {
speed = <1000>;
full-duplex;
mdio@fc000 {
reg = <0x1>;
reg = <0x2>;
This time I can see fm1-mac9 but I can't ping it. Other ports that were working fine also can't ping it.
fm1-mac9  Link encap:Ethernet  HWaddr 00:04:9f:04:4d:e5
          Memory:1af0000-1af0fff
root@ls1043ardb:~# ifconfig fm1-mac9 192.168.0.100/16
root@ls1043ardb:~# ping 192.168.20.10
PING 192.168.20.10 (192.168.20.10) 56(84) bytes of data.
From 192.168.0.100 icmp_seq=1 Destination Host Unreachable
From 192.168.0.100 icmp_seq=2 Destination Host Unreachable
From 192.168.0.100 icmp_seq=3 Destination Host Unreachable
^C
--- 192.168.20.10 ping statistics ---
4 packets transmitted, 0 received, +3 errors, 100% packet loss, time 3000ms
pipe 3
[    4.455602] fsl_dpa fsl,dpaa:ethernet@2 fm1-mac3: renamed from eth0
[    4.549437] udevd[1494]: renamed network interface eth0 to fm1-mac3
[    4.549772] fsl_dpa fsl,dpaa:ethernet@8 fm1-mac9: renamed from eth2
[    4.629395] udevd[1497]: renamed network interface eth2 to fm1-mac9
[    4.631714] fsl_dpa fsl,dpaa:ethernet@3 fm1-mac4: renamed from eth1
[    4.719371] udevd[1495]: renamed network interface eth1 to fm1-mac4
root@ls1043ardb:~# ifconfig fm1-mac9 down
[  174.695225] cpu 0: > WARNING (FM-Port) [CPU00, /home/yhoh/wk-qoriqSDKv2-1703/qoriqSDKv2-1703_dru100_V1_180316/build_ls1043ardb/tmp/work-shared/ls1043ardb/kernel-source/drivers/net/ethernet/freescale/sdk_fman/Peripherals/FM/Port/fm_port.c:3547 FM_PORT_Disable]:
[  174.718163] cpu 0: FM-0-port-10g-TX-0: BMI or QMI is Busy. Port forced down[  174.725120] cpu 0:
root@ls1043ardb:~# ifconfig fm1-mac3 192.168.0.100/16
^C
6 packets transmitted, 0 received, +3 errors, 100% packet loss, time 5008ms
pipe 3
root@ls1043ardb:~# ifconfig fm1-mac3 down
root@ls1043ardb:~# ifconfig fm1-mac4 192.168.0.100/16
[  267.330310] fsl_dpa fsl,dpaa:ethernet@3 fm1-mac4: Could not connect to PHY /soc/fman@1a00000/mdio@fc000/ethernet-phy@2
[  267.341016] fsl_dpa fsl,dpaa:ethernet@3 fm1-mac4: init_phy() = -19
SIOCSIFFLAGS: No such device
What's the problem? I need help.
Thank you,
Gyosun.
Gyosun
  cell-index = <0>;
  cell-index = <0>;
  cell-index = <0>;
&fman0 {
  ethernet@e4000 {
  ethernet@e6000 {
  ethernet@f0000 {
  mdio@fc000 {
      reg = <0x0>;
      reg = <0x1>;
      reg = <0x3>;
%3CLINGO-SUB%20id%3D%22lingo-sub-1996155%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELS1043A%20Ethernet%20Additional%20Issue!%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1996155%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%3CP%3EI%20am%20using%20LS1043A%20custom%20board.%3CBR%20%2F%3ESDK%20is%20QORIQ-SDK-2.0-1703.%3C%2FP%3E%3CP%3EPreviously%2C%20Ethernet%20was%20used%20well%20as%20follows.%3CBR%20%2F%3ESRDS_PRTCL_S1_RCW%5B128%3A143%5D%3A%20%3CFONT%20color%3D%22%23FF0000%22%3E1460%3C%2FFONT%3E%3CBR%20%2F%3ESerdesA%20-%20XFI%20-%20Retimer%20-%2010G%20SFP%2B%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3EReset%20Configuration%20Word%20(RCW)%3A%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E00000000%3A%2008100010%200a000000%2000000000%2000000000%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E00000010%3A%20%3CFONT%20color%3D%22%23FF0000%22%3E1460%3C%2FFONT%3E0002%2080004012%2060040000%20c1002000%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E00000020%3A%2000000000%2000000000%2000000000%200002e806%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E00000030%3A%2000000000%20001e1308%2000000096%2000000001%3C%2FFONT%3E%3C%2FP%3E%3CP%3EWe%20needed%20additional%201G%20Ethernet%2C%20so%20we%20changed%20the%20existing%2010G%20slot%20to%201G.%3CBR%20%2F%3ESRDS_PRTCL_S1_RCW%5B128%3A143%5D%3A%20%3CFONT%20color%3D%22%23FF0000%22%3E3460%3C%2FFONT%3E%3CBR%20%2F%3ESerdesA%20-%20SGMII%20-%20PHY%20-%20RJ45%3C%2FP%3E%3CP%3E%3CFONT%20color%3D%22%23FF0000%22%3EI%20changed%20RCW%20from%201460%20to%203460%20and%20tried%20to%20boot%2C%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF0000%22%3Ebut%20even%20u-boot%20doesn't%20show%20any%20logs.%3C%2FFONT%3E%3C%2FP%3E%3CP%3EDo%20I%20need%20to%20change%20the%20fsl_fman_ucode_ls1043_r1.1_108_4_9.bin%20file%3F%3CBR%20%2F%3EIf%20I%20need%20to%20change%20it%2C%20how%20can%20I%20do%20it%20without%20the%20source%20code%3F%3CBR%20%2F%3EOr%20do%20you%20know%20what%20else%20is%20wrong%3F%3C%2FP%3E%3CP%3EThank%20you%2C%3CBR%20%2F%3EBest%20Regards%2C%3CBR%20%2F%3EGyosun.%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1998487%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20LS1043A%20Ethernet%20Additional%20Issue!%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1998487%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3EI%20solved%20it%20myself%20and%20share%20it%20for%20help.%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3EI%20set%20up%20dts%20like%20this%3A%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3Earch%2Farm64%2Fboot%2Fdts%2Ffreescale%2Ffsl-ls1043a.dtsi%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3Efman0_10g_rx0%3A%20port%4090000%20%7B%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%20cell-index%20%3D%20%26lt%3B0%26gt%3B%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%20compatible%20%3D%20%22fsl%2Cfman-port-10g-rx%22%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%20reg%20%3D%20%26lt%3B0x90000%200x1000%26gt%3B%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%7D%3B%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3Efman0_10g_tx0%3A%20port%40b0000%20%7B%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%20cell-index%20%3D%20%26lt%3B0%26gt%3B%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%20compatible%20%3D%20%22fsl%2Cfman-port-10g-tx%22%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%20reg%20%3D%20%26lt%3B0xb0000%200x1000%26gt%3B%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%20fsl%2Cqman-channel-id%20%3D%20%26lt%3B0x800%26gt%3B%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%7D%3B%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3Efm1mac9%3A%20ethernet%40f0000%20%7B%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%20cell-index%20%3D%20%26lt%3B0%26gt%3B%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%20compatible%20%3D%20%22fsl%2Cfman-memac%22%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%20reg%20%3D%20%26lt%3B0xf0000%200x1000%26gt%3B%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%20fsl%2Cport-handles%20%3D%20%26lt%3B%26amp%3Bfman0_10g_rx0%20%26amp%3Bfman0_10g_tx0%26gt%3B%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%7D%3B%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3Earch%2Farm64%2Fboot%2Fdts%2Ffreescale%2Ffsl-ls1043a-rdb.dts%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%26amp%3Bfman0%20%7B%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%20ethernet%40e4000%20%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20phy-handle%20%3D%20%26lt%3B%26amp%3Brgmii_phy1%26gt%3B%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20phy-connection-type%20%3D%20%22rgmii%22%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%20%7D%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%20ethernet%40e6000%20%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20phy-handle%20%3D%20%26lt%3B%26amp%3Brgmii_phy2%26gt%3B%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20phy-connection-type%20%3D%20%22rgmii%22%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%20%7D%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%20ethernet%40f0000%20%7B%26nbsp%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20phy-handle%20%3D%20%26lt%3B%26amp%3Bsgmii_phy1%26gt%3B%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20phy-connection-type%20%3D%20%22sgmii%22%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%20%7D%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%20mdio%40fc000%20%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20rgmii_phy1%3A%20ethernet-phy%400%20%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20reg%20%3D%20%26lt%3B0x0%26gt%3B%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%7D%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20rgmii_phy2%3A%20ethernet-phy%401%20%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20reg%20%3D%20%26lt%3B0x1%26gt%3B%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%7D%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20sgmii_phy1%3A%20ethernet-phy%403%20%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20reg%20%3D%20%26lt%3B0x3%26gt%3B%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%7D%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%20%7D%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%7D%3B%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3EWhen%20changing%20from%20xfi%20to%20sgmii%2C%20you%20need%20to%20change%20SD1_REF_CLK%20from%20156MHz%20to%20125MHz.%26nbsp%3B%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3EI%20reset%20the%20phy%20address%20in%20uboot%20and%20dts.%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1997709%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20LS1043A%20Ethernet%20Additional%20Issue!%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1997709%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3ESomehow%20the%20log%20was%20printed.%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3EIt%20was%20recognized%20as%20follows%20in%20u-boot.%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3D%26gt%3B%20mdio%20list%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3EFSL_MDIO0%3A%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E0%20-%20AR8035%20%26lt%3B--%26gt%3B%20FM1%40DTSEC6%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E1%20-%20AR8035%20%26lt%3B--%26gt%3B%20FM1%40DTSEC4%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E3%20-%20AR8031%2FAR8033%20%26lt%3B--%26gt%3B%20FM1%40DTSEC9%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3EFM_TGEC_MDIO%3A%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3D%26gt%3B%20mii%20info%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3EPHY%200x00%3A%20OUI%20%3D%200x1374%2C%20Model%20%3D%200x07%2C%20Rev%20%3D%200x02%2C%201000baseX%2C%20HDX%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3EPHY%200x01%3A%20OUI%20%3D%200x1374%2C%20Model%20%3D%200x07%2C%20Rev%20%3D%200x02%2C%201000baseX%2C%20HDX%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3EPHY%200x03%3A%20OUI%20%3D%200x1374%2C%20Model%20%3D%200x07%2C%20Rev%20%3D%200x04%2C%201000baseX%2C%20FDX%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3D%26gt%3B%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3EAfter%20booting%2C%26nbsp%3B%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3ECASE1%3A%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3EThe%20dts%20file%20is%20set%20up%20as%20follows%3A%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3Earch%2Farm64%2Fboot%2Fdts%2Ffreescale%2Ffsl-ls1043a.dtsi%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3Efman0%3A%20fman%401a00000%20%7B%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E...%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Efman0_rx8%3A%20port%4090000%20%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Ecell-index%20%3D%20%26lt%3B8%26gt%3B%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Ecompatible%20%3D%20%22fsl%2Cfman-port-1g-rx%22%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Ereg%20%3D%20%26lt%3B0x90000%200x1000%26gt%3B%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Efman0_tx8%3A%20port%40b0000%20%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Ecell-index%20%3D%20%26lt%3B8%26gt%3B%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Ecompatible%20%3D%20%22fsl%2Cfman-port-1g-tx%22%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Ereg%20%3D%20%26lt%3B0xb0000%200x1000%26gt%3B%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Efm1mac9%3A%20ethernet%40f0000%20%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Ecell-index%20%3D%20%26lt%3B8%26gt%3B%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Ecompatible%20%3D%20%22fsl%2Cfman-memac%22%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Ereg%20%3D%20%26lt%3B0xf0000%200x1000%26gt%3B%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Efsl%2Cport-handles%20%3D%20%26lt%3B%26amp%3Bfman0_rx8%20%26amp%3Bfman0_tx8%26gt%3B%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E...%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%7D%3B%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3Earch%2Farm64%2Fboot%2Fdts%2Ffreescale%2Ffsl-ls1043a-rdb.dts%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%26amp%3Bfman0%20%7B%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Eethernet%40e4000%20%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Estatus%20%3D%20%22okay%22%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Ephy-handle%20%3D%20%26lt%3B%26amp%3Brgmii_phy1%26gt%3B%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Ephy-connection-type%20%3D%20%22rgmii%22%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Eethernet%40e6000%20%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Estatus%20%3D%20%22okay%22%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Ephy-handle%20%3D%20%26lt%3B%26amp%3Brgmii_phy2%26gt%3B%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Ephy-connection-type%20%3D%20%22rgmii%22%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Eethernet%40f0000%20%7B%26nbsp%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Estatus%20%3D%20%22okay%22%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Ephy-handle%20%3D%20%26lt%3B%26amp%3Bsgmii_phy1%26gt%3B%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Ephy-connection-type%20%3D%20%22sgmii%22%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Emdio%40fc000%20%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Ergmii_phy1%3A%20ethernet-phy%401%20%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Ereg%20%3D%20%26lt%3B0x1%26gt%3B%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Ergmii_phy2%3A%20ethernet-phy%402%20%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Ereg%20%3D%20%26lt%3B0x2%26gt%3B%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Esgmii_phy1%3A%20ethernet-phy%403%20%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Ereg%20%3D%20%26lt%3B0x3%26gt%3B%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%7D%3B%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3EI%20checked%20with%20ifconfig%20-a%20and%20fm1-mac9%20is%20not%20visible%20at%20all.%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3Eroot%40ls1043ardb%3A~%23%20ifconfig%20-a%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3Efm1-mac3%26nbsp%3B%20Link%20encap%3AEthernet%26nbsp%3B%20HWaddr%20fc%3Ac2%3A3d%3A31%3A76%3A54%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20BROADCAST%20MULTICAST%26nbsp%3B%20MTU%3A1500%26nbsp%3B%20Metric%3A1%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20RX%20packets%3A0%20errors%3A0%20dropped%3A0%20overruns%3A0%20frame%3A0%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20TX%20packets%3A0%20errors%3A0%20dropped%3A0%20overruns%3A0%20carrier%3A0%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20collisions%3A0%20txqueuelen%3A1000%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20RX%20bytes%3A0%20(0.0%20B)%26nbsp%3B%20TX%20bytes%3A0%20(0.0%20B)%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20Memory%3A1ae4000-1ae4fff%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3Efm1-mac4%26nbsp%3B%20Link%20encap%3AEthernet%26nbsp%3B%20HWaddr%2000%3A04%3A9f%3A04%3A4d%3Ae2%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20BROADCAST%20MULTICAST%26nbsp%3B%20MTU%3A1500%26nbsp%3B%20Metric%3A1%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20RX%20packets%3A0%20errors%3A0%20dropped%3A0%20overruns%3A0%20frame%3A0%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20TX%20packets%3A0%20errors%3A0%20dropped%3A0%20overruns%3A0%20carrier%3A0%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20collisions%3A0%20txqueuelen%3A1000%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20RX%20bytes%3A0%20(0.0%20B)%26nbsp%3B%20TX%20bytes%3A0%20(0.0%20B)%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20Memory%3A1ae6000-1ae6fff%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3Eroot%40ls1043ardb%3A~%23%20dmesg%20%7C%20grep%20fm1%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%5B%26nbsp%3B%20%26nbsp%3B%204.458930%5D%20fsl_dpa%20fsl%2Cdpaa%3Aethernet%402%20fm1-mac3%3A%20renamed%20from%20eth0%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%5B%26nbsp%3B%20%26nbsp%3B%204.519680%5D%20udevd%5B1353%5D%3A%20renamed%20network%20interface%20eth0%20to%20fm1-mac3%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%5B%26nbsp%3B%20%26nbsp%3B%204.526057%5D%20fsl_dpa%20fsl%2Cdpaa%3Aethernet%403%20fm1-mac4%3A%20renamed%20from%20eth1%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%5B%26nbsp%3B%20%26nbsp%3B%204.669416%5D%20udevd%5B1354%5D%3A%20renamed%20network%20interface%20eth1%20to%20fm1-mac4%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3Eroot%40ls1043ardb%3A~%23%20uname%20-a%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3ELinux%20ls1043ardb%204.1.35-rt41%20%2316%20SMP%20Tue%20Nov%208%2019%3A14%3A01%20KST%202022%20aarch64%20GNU%2FLinux%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3ECASE2%3A%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3EThe%20dts%20file%20is%20set%20up%20as%20follows%3A%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3Earch%2Farm64%2Fboot%2Fdts%2Ffreescale%2Ffsl-ls1043a.dtsi%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3Efman0%3A%20fman%401a00000%20%7B%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E...%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Efman0_10g_rx0%3A%20port%4090000%20%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Ecell-index%20%3D%20%26lt%3B0%26gt%3B%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Ecompatible%20%3D%20%22fsl%2Cfman-port-10g-rx%22%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Ereg%20%3D%20%26lt%3B0x90000%200x1000%26gt%3B%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Efman0_10g_tx0%3A%20port%40b0000%20%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Ecell-index%20%3D%20%26lt%3B0%26gt%3B%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Ecompatible%20%3D%20%22fsl%2Cfman-port-10g-tx%22%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Ereg%20%3D%20%26lt%3B0xb0000%200x1000%26gt%3B%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Efsl%2Cqman-channel-id%20%3D%20%26lt%3B0x800%26gt%3B%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Efm1mac9%3A%20ethernet%40f0000%20%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Ecell-index%20%3D%20%26lt%3B0%26gt%3B%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Ecompatible%20%3D%20%22fsl%2Cfman-memac%22%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Ereg%20%3D%20%26lt%3B0xf0000%200x1000%26gt%3B%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Efsl%2Cport-handles%20%3D%20%26lt%3B%26amp%3Bfman0_10g_rx0%20%26amp%3Bfman0_10g_tx0%26gt%3B%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E...%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%7D%3B%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3Earch%2Farm64%2Fboot%2Fdts%2Ffreescale%2Ffsl-ls1043a-rdb.dts%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%26amp%3Bfman0%20%7B%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Eethernet%40e4000%20%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Estatus%20%3D%20%22okay%22%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Ephy-handle%20%3D%20%26lt%3B%26amp%3Brgmii_phy1%26gt%3B%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Ephy-connection-type%20%3D%20%22rgmii%22%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Eethernet%40e6000%20%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Estatus%20%3D%20%22okay%22%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Ephy-handle%20%3D%20%26lt%3B%26amp%3Brgmii_phy2%26gt%3B%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Ephy-connection-type%20%3D%20%22rgmii%22%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Eethernet%40f0000%20%7B%26nbsp%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Ephy-connection-type%20%3D%20%22sgmii%22%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Efixed-link%20%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Espeed%20%3D%20%26lt%3B1000%26gt%3B%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Efull-duplex%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Emdio%40fc000%20%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Ergmii_phy1%3A%20ethernet-phy%401%20%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Ereg%20%3D%20%26lt%3B0x1%26gt%3B%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Ergmii_phy2%3A%20ethernet-phy%402%20%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Ereg%20%3D%20%26lt%3B0x2%26gt%3B%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%7D%3B%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3EThis%20time%20I%20can%20see%20fm1-mac9%20but%20I%20can't%20ping%20it.%20Other%20ports%20that%20were%20working%20fine%20also%20can't%20ping%20it.%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3Eroot%40ls1043ardb%3A~%23%20ifconfig%20-a%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3Efm1-mac3%26nbsp%3B%20Link%20encap%3AEthernet%26nbsp%3B%20HWaddr%20fc%3Ac2%3A3d%3A31%3A76%3A54%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20BROADCAST%20MULTICAST%26nbsp%3B%20MTU%3A1500%26nbsp%3B%20Metric%3A1%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20RX%20packets%3A0%20errors%3A0%20dropped%3A0%20overruns%3A0%20frame%3A0%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20TX%20packets%3A0%20errors%3A0%20dropped%3A0%20overruns%3A0%20carrier%3A0%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20collisions%3A0%20txqueuelen%3A1000%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20RX%20bytes%3A0%20(0.0%20B)%26nbsp%3B%20TX%20bytes%3A0%20(0.0%20B)%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20Memory%3A1ae4000-1ae4fff%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3Efm1-mac4%26nbsp%3B%20Link%20encap%3AEthernet%26nbsp%3B%20HWaddr%2000%3A04%3A9f%3A04%3A4d%3Ae2%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20BROADCAST%20MULTICAST%26nbsp%3B%20MTU%3A1500%26nbsp%3B%20Metric%3A1%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20RX%20packets%3A0%20errors%3A0%20dropped%3A0%20overruns%3A0%20frame%3A0%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20TX%20packets%3A0%20errors%3A0%20dropped%3A0%20overruns%3A0%20carrier%3A0%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20collisions%3A0%20txqueuelen%3A1000%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20RX%20bytes%3A0%20(0.0%20B)%26nbsp%3B%20TX%20bytes%3A0%20(0.0%20B)%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20Memory%3A1ae6000-1ae6fff%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3Efm1-mac9%26nbsp%3B%20Link%20encap%3AEthernet%26nbsp%3B%20HWaddr%2000%3A04%3A9f%3A04%3A4d%3Ae5%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20BROADCAST%20MULTICAST%26nbsp%3B%20MTU%3A1500%26nbsp%3B%20Metric%3A1%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20RX%20packets%3A0%20errors%3A0%20dropped%3A0%20overruns%3A0%20frame%3A0%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20TX%20packets%3A0%20errors%3A0%20dropped%3A0%20overruns%3A0%20carrier%3A0%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20collisions%3A0%20txqueuelen%3A1000%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20RX%20bytes%3A0%20(0.0%20B)%26nbsp%3B%20TX%20bytes%3A0%20(0.0%20B)%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20Memory%3A1af0000-1af0fff%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3Eroot%40ls1043ardb%3A~%23%20ifconfig%20fm1-mac9%20192.168.0.100%2F16%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3Eroot%40ls1043ardb%3A~%23%20ping%20192.168.20.10%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3EPING%20192.168.20.10%20(192.168.20.10)%2056(84)%20bytes%20of%20data.%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3EFrom%20192.168.0.100%20icmp_seq%3D1%20Destination%20Host%20Unreachable%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3EFrom%20192.168.0.100%20icmp_seq%3D2%20Destination%20Host%20Unreachable%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3EFrom%20192.168.0.100%20icmp_seq%3D3%20Destination%20Host%20Unreachable%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%5EC%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E---%20192.168.20.10%20ping%20statistics%20---%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E4%20packets%20transmitted%2C%200%20received%2C%20%2B3%20errors%2C%20100%25%20packet%20loss%2C%20time%203000ms%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3Epipe%203%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3Eroot%40ls1043ardb%3A~%23%20dmesg%20%7C%20grep%20fm1%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%5B%26nbsp%3B%20%26nbsp%3B%204.455602%5D%20fsl_dpa%20fsl%2Cdpaa%3Aethernet%402%20fm1-mac3%3A%20renamed%20from%20eth0%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%5B%26nbsp%3B%20%26nbsp%3B%204.549437%5D%20udevd%5B1494%5D%3A%20renamed%20network%20interface%20eth0%20to%20fm1-mac3%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%5B%26nbsp%3B%20%26nbsp%3B%204.549772%5D%20fsl_dpa%20fsl%2Cdpaa%3Aethernet%408%20fm1-mac9%3A%20renamed%20from%20eth2%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%5B%26nbsp%3B%20%26nbsp%3B%204.629395%5D%20udevd%5B1497%5D%3A%20renamed%20network%20interface%20eth2%20to%20fm1-mac9%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%5B%26nbsp%3B%20%26nbsp%3B%204.631714%5D%20fsl_dpa%20fsl%2Cdpaa%3Aethernet%403%20fm1-mac4%3A%20renamed%20from%20eth1%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%5B%26nbsp%3B%20%26nbsp%3B%204.719371%5D%20udevd%5B1495%5D%3A%20renamed%20network%20interface%20eth1%20to%20fm1-mac4%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3Eroot%40ls1043ardb%3A~%23%20ifconfig%20fm1-mac9%20down%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%5B%26nbsp%3B%20174.695225%5D%20cpu%200%3A%20%26gt%3B%20WARNING%20(FM-Port)%20%5BCPU00%2C%20%2Fhome%2Fyhoh%2Fwk-qoriqSDKv2-1703%2FqoriqSDKv2-1703_dru100_V1_180316%2Fbuild_ls1043ardb%2Ftmp%2Fwork-shared%2Fls1043ardb%2Fkernel-source%2Fdrivers%2Fnet%2Fethernet%2Ffreescale%2Fsdk_fman%2FPeripherals%2FFM%2FPort%2Ffm_port.c%3A3547%20FM_PORT_Disable%5D%3A%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%5B%26nbsp%3B%20174.718163%5D%20cpu%200%3A%20FM-0-port-10g-TX-0%3A%20BMI%20or%20QMI%20is%20Busy.%20Port%20forced%20down%5B%26nbsp%3B%20174.725120%5D%20cpu%200%3A%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3Eroot%40ls1043ardb%3A~%23%20ifconfig%20fm1-mac3%20192.168.0.100%2F16%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3Eroot%40ls1043ardb%3A~%23%20ping%20192.168.20.10%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3EPING%20192.168.20.10%20(192.168.20.10)%2056(84)%20bytes%20of%20data.%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3EFrom%20192.168.0.100%20icmp_seq%3D1%20Destination%20Host%20Unreachable%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3EFrom%20192.168.0.100%20icmp_seq%3D2%20Destination%20Host%20Unreachable%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3EFrom%20192.168.0.100%20icmp_seq%3D3%20Destination%20Host%20Unreachable%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%5EC%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E---%20192.168.20.10%20ping%20statistics%20---%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E6%20packets%20transmitted%2C%200%20received%2C%20%2B3%20errors%2C%20100%25%20packet%20loss%2C%20time%205008ms%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3Epipe%203%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3Eroot%40ls1043ardb%3A~%23%20ifconfig%20fm1-mac3%20down%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3Eroot%40ls1043ardb%3A~%23%20ifconfig%20fm1-mac4%20192.168.0.100%2F16%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%5B%26nbsp%3B%20267.330310%5D%20fsl_dpa%20fsl%2Cdpaa%3Aethernet%403%20fm1-mac4%3A%20Could%20not%20connect%20to%20PHY%20%2Fsoc%2Ffman%401a00000%2Fmdio%40fc000%2Fethernet-phy%402%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%5B%26nbsp%3B%20267.341016%5D%20fsl_dpa%20fsl%2Cdpaa%3Aethernet%403%20fm1-mac4%3A%20init_phy()%20%3D%20-19%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3ESIOCSIFFLAGS%3A%20No%20such%20device%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CA%20href%3D%22mailto%3Aroot%40ls1043ardb%3A~%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Eroot%40ls1043ardb%3A~%23%3C%2FA%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3EWhat's%20the%20problem%3F%20I%20need%20help.%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3EThank%20you%2C%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3EBest%20Regards%2C%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3EGyosun.%3C%2FFONT%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E
