LS1043A Ethernet Additional Issue!
4,410 次查看
Gyosun
I am using LS1043A custom board.
SDK is QORIQ-SDK-2.0-1703.
Previously, Ethernet was used well as follows.
SRDS_PRTCL_S1_RCW[128:143]: 1460
SerdesA - XFI - Retimer - 10G SFP+
Reset Configuration Word (RCW):
00000000: 08100010 0a000000 00000000 00000000
00000010: 14600002 80004012 60040000 c1002000
00000020: 00000000 00000000 00000000 0002e806
00000030: 00000000 001e1308 00000096 00000001
We needed additional 1G Ethernet, so we changed the existing 10G slot to 1G.
SRDS_PRTCL_S1_RCW[128:143]: 3460
SerdesA - SGMII - PHY - RJ45
I changed RCW from 1460 to 3460 and tried to boot,
but even u-boot doesn't show any logs.
Do I need to change the fsl_fman_ucode_ls1043_r1.1_108_4_9.bin file?
If I need to change it, how can I do it without the source code?
Or do you know what else is wrong?
Thank you,
Gyosun.
4,361 次查看
Gyosun
I solved it myself and share it for help.
I set up dts like this:
arch/arm64/boot/dts/freescale/fsl-ls1043a.dtsi
fman0_10g_rx0: port@90000 {
  cell-index = <0>;
  compatible = "fsl,fman-port-10g-rx";
  reg = <0x90000 0x1000>;
fman0_10g_tx0: port@b0000 {
  cell-index = <0>;
  compatible = "fsl,fman-port-10g-tx";
  reg = <0xb0000 0x1000>;
  fsl,qman-channel-id = <0x800>;
fm1mac9: ethernet@f0000 {
  cell-index = <0>;
  compatible = "fsl,fman-memac";
  reg = <0xf0000 0x1000>;
  fsl,port-handles = <&fman0_10g_rx0 &fman0_10g_tx0>;
arch/arm64/boot/dts/freescale/fsl-ls1043a-rdb.dts
&fman0 {
  ethernet@e4000 {
    phy-handle = <&rgmii_phy1>;
    phy-connection-type = "rgmii";
  ethernet@e6000 {
    phy-handle = <&rgmii_phy2>;
  ethernet@f0000 {
    phy-handle = <&sgmii_phy1>;
    phy-connection-type = "sgmii";
  mdio@fc000 {
    rgmii_phy1: ethernet-phy@0 {
      reg = <0x0>;
    rgmii_phy2: ethernet-phy@1 {
      reg = <0x1>;
    sgmii_phy1: ethernet-phy@3 {
      reg = <0x3>;
When changing from xfi to sgmii, you need to change SD1_REF_CLK from 156MHz to 125MHz.
I reset the phy address in uboot and dts.
4,373 次查看
Gyosun
Somehow the log was printed.
It was recognized as follows in u-boot.
=> mdio list
FSL_MDIO0:
0 - AR8035 <--> FM1@DTSEC6
1 - AR8035 <--> FM1@DTSEC4
3 - AR8031/AR8033 <--> FM1@DTSEC9
FM_TGEC_MDIO:
=> mii info
PHY 0x00: OUI = 0x1374, Model = 0x07, Rev = 0x02, 1000baseX, HDX
PHY 0x01: OUI = 0x1374, Model = 0x07, Rev = 0x02, 1000baseX, HDX
PHY 0x03: OUI = 0x1374, Model = 0x07, Rev = 0x04, 1000baseX, FDX
After booting,
CASE1:
The dts file is set up as follows:
fman0: fman@1a00000 {
fman0_rx8: port@90000 {
cell-index = <8>;
compatible = "fsl,fman-port-1g-rx";
fman0_tx8: port@b0000 {
cell-index = <8>;
compatible = "fsl,fman-port-1g-tx";
cell-index = <8>;
fsl,port-handles = <&fman0_rx8 &fman0_tx8>;
&fman0 {
ethernet@e4000 {
status = "okay";
ethernet@e6000 {
status = "okay";
ethernet@f0000 {
status = "okay";
mdio@fc000 {
rgmii_phy1: ethernet-phy@1 {
reg = <0x1>;
rgmii_phy2: ethernet-phy@2 {
reg = <0x2>;
reg = <0x3>;
I checked with ifconfig -a and fm1-mac9 is not visible at all.
root@ls1043ardb:~# ifconfig -a
fm1-mac3  Link encap:Ethernet  HWaddr fc:c2:3d:31:76:54
          BROADCAST MULTICAST  MTU:1500  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
          Memory:1ae4000-1ae4fff
fm1-mac4  Link encap:Ethernet  HWaddr 00:04:9f:04:4d:e2
          Memory:1ae6000-1ae6fff
root@ls1043ardb:~# dmesg | grep fm1
[    4.458930] fsl_dpa fsl,dpaa:ethernet@2 fm1-mac3: renamed from eth0
[    4.519680] udevd[1353]: renamed network interface eth0 to fm1-mac3
[    4.526057] fsl_dpa fsl,dpaa:ethernet@3 fm1-mac4: renamed from eth1
[    4.669416] udevd[1354]: renamed network interface eth1 to fm1-mac4
root@ls1043ardb:~# uname -a
Linux ls1043ardb 4.1.35-rt41 #16 SMP Tue Nov 8 19:14:01 KST 2022 aarch64 GNU/Linux
CASE2:
cell-index = <0>;
cell-index = <0>;
cell-index = <0>;
&fman0 {
ethernet@e4000 {
status = "okay";
ethernet@e6000 {
status = "okay";
ethernet@f0000 {
fixed-link {
speed = <1000>;
full-duplex;
mdio@fc000 {
reg = <0x1>;
reg = <0x2>;
This time I can see fm1-mac9 but I can't ping it. Other ports that were working fine also can't ping it.
fm1-mac9  Link encap:Ethernet  HWaddr 00:04:9f:04:4d:e5
          Memory:1af0000-1af0fff
root@ls1043ardb:~# ifconfig fm1-mac9 192.168.0.100/16
root@ls1043ardb:~# ping 192.168.20.10
PING 192.168.20.10 (192.168.20.10) 56(84) bytes of data.
From 192.168.0.100 icmp_seq=1 Destination Host Unreachable
From 192.168.0.100 icmp_seq=2 Destination Host Unreachable
From 192.168.0.100 icmp_seq=3 Destination Host Unreachable
^C
--- 192.168.20.10 ping statistics ---
4 packets transmitted, 0 received, +3 errors, 100% packet loss, time 3000ms
pipe 3
[    4.455602] fsl_dpa fsl,dpaa:ethernet@2 fm1-mac3: renamed from eth0
[    4.549437] udevd[1494]: renamed network interface eth0 to fm1-mac3
[    4.549772] fsl_dpa fsl,dpaa:ethernet@8 fm1-mac9: renamed from eth2
[    4.629395] udevd[1497]: renamed network interface eth2 to fm1-mac9
[    4.631714] fsl_dpa fsl,dpaa:ethernet@3 fm1-mac4: renamed from eth1
[    4.719371] udevd[1495]: renamed network interface eth1 to fm1-mac4
root@ls1043ardb:~# ifconfig fm1-mac9 down
[  174.695225] cpu 0: > WARNING (FM-Port) [CPU00, /home/yhoh/wk-qoriqSDKv2-1703/qoriqSDKv2-1703_dru100_V1_180316/build_ls1043ardb/tmp/work-shared/ls1043ardb/kernel-source/drivers/net/ethernet/freescale/sdk_fman/Peripherals/FM/Port/fm_port.c:3547 FM_PORT_Disable]:
[  174.718163] cpu 0: FM-0-port-10g-TX-0: BMI or QMI is Busy. Port forced down[  174.725120] cpu 0:
root@ls1043ardb:~# ifconfig fm1-mac3 192.168.0.100/16
^C
6 packets transmitted, 0 received, +3 errors, 100% packet loss, time 5008ms
pipe 3
root@ls1043ardb:~# ifconfig fm1-mac3 down
root@ls1043ardb:~# ifconfig fm1-mac4 192.168.0.100/16
[  267.330310] fsl_dpa fsl,dpaa:ethernet@3 fm1-mac4: Could not connect to PHY /soc/fman@1a00000/mdio@fc000/ethernet-phy@2
[  267.341016] fsl_dpa fsl,dpaa:ethernet@3 fm1-mac4: init_phy() = -19
SIOCSIFFLAGS: No such device
What's the problem? I need help.
Thank you,
Gyosun.
4,362 次查看
Gyosun
  cell-index = <0>;
  cell-index = <0>;
  cell-index = <0>;
&fman0 {
  ethernet@e4000 {
  ethernet@e6000 {
  ethernet@f0000 {
  mdio@fc000 {
      reg = <0x0>;
      reg = <0x1>;
      reg = <0x3>;
%3CLINGO-SUB%20id%3D%22lingo-sub-1996155%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELS1043A%20%E4%BB%A5%E5%A4%AA%E7%BD%91%E9%99%84%E5%8A%A0%E9%97%AE%E9%A2%98%EF%BC%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1996155%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%20LS1043A%20%E5%AE%9A%E5%88%B6%E6%9D%BF%E3%80%82%3CBR%20%2F%3ESDK%E6%98%AFQORIQ-SDK-2.0-1703%E3%80%82%3C%2FP%3E%3CP%3E%E4%BB%A5%E5%89%8D%EF%BC%8C%E4%BB%A5%E5%A4%AA%E7%BD%91%E7%9A%84%E4%BD%BF%E7%94%A8%E6%83%85%E5%86%B5%E5%A6%82%E4%B8%8B%E3%80%82%3CBR%20%2F%3ESRDS_PRTCL_S1_RCW%5B128%3A143%5D%3A%20%3CFONT%20color%3D%22%23FF0000%22%3E1460%3C%2FFONT%3E%3CBR%20%2F%3E%20SerdesA%20-%20XFI%20-%20%E9%87%8D%E5%AE%9A%E6%97%B6%E5%99%A8%20-%2010G%20SFP%2B%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%E5%A4%8D%E4%BD%8D%E9%85%8D%E7%BD%AE%E5%AD%97%EF%BC%88RCW%EF%BC%89%EF%BC%9A%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E00000000%3A%2008100010%200a000000%2000000000%2000000000%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E00000010%3A%20%3CFONT%20color%3D%22%23FF0000%22%3E1460%3C%2FFONT%3E%200002%2080004012%2060040000%20c1002000%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E00000020%3A%2000000000%2000000000%2000000000%200002e806%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E00000030%3A%2000000000%20001e1308%2000000096%2000000001%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%AC%E9%9C%80%E8%A6%81%E9%A2%9D%E5%A4%96%E7%9A%84%201G%20%E4%BB%A5%E5%A4%AA%E7%BD%91%EF%BC%8C%E5%9B%A0%E6%AD%A4%E6%88%91%E4%BB%AC%E5%B0%86%E7%8E%B0%E6%9C%89%E7%9A%84%2010G%20%E6%8F%92%E6%A7%BD%E6%9B%B4%E6%94%B9%E4%B8%BA%201G%E3%80%82%3CBR%20%2F%3E%20SRDS_PRTCL_S1_RCW%5B128%3A143%5D%3A%20%3CFONT%20color%3D%22%23FF0000%22%3E3460%3C%2FFONT%3E%3CBR%20%2F%3E%20SerdesA%20-%20SGMII%20-%20PHY%20-%20RJ45%3C%2FP%3E%3CP%3E%3CFONT%20color%3D%22%23FF0000%22%3E%E6%88%91%E5%B0%86%20RCW%20%E4%BB%8E%201460%20%E6%94%B9%E4%B8%BA%203460%20%E5%B9%B6%E5%B0%9D%E8%AF%95%E5%90%AF%E5%8A%A8%EF%BC%8C%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF0000%22%3E%E4%BD%86%E5%8D%B3%E4%BD%BF%20u-boot%20%E4%B9%9F%E6%B2%A1%E6%9C%89%E6%98%BE%E7%A4%BA%E4%BB%BB%E4%BD%95%E6%97%A5%E5%BF%97%E3%80%82%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%E6%88%91%E9%9C%80%E8%A6%81%E6%9B%B4%E6%94%B9%20fsl_fman_ucode_ls1043_r1.1_108_4_9.bin%20%E6%96%87%E4%BB%B6%E5%90%97%EF%BC%9F%3CBR%20%2F%3E%E5%A6%82%E6%9E%9C%E6%88%91%E9%9C%80%E8%A6%81%E6%9B%B4%E6%94%B9%E5%AE%83%EF%BC%8C%E6%B2%A1%E6%9C%89%E6%BA%90%E4%BB%A3%E7%A0%81%E6%88%91%E8%AF%A5%E6%80%8E%E4%B9%88%E5%81%9A%EF%BC%9F%3CBR%20%2F%3E%E6%88%96%E8%80%85%E6%82%A8%E7%9F%A5%E9%81%93%E8%BF%98%E6%9C%89%E4%BB%80%E4%B9%88%E9%97%AE%E9%A2%98%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E4%BD%A0%EF%BC%8C%3CBR%20%2F%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3CBR%20%2F%3E%E6%AF%93%E9%A1%BA%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1998487%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9ALS1043A%20%E4%BB%A5%E5%A4%AA%E7%BD%91%E9%99%84%E5%8A%A0%E9%97%AE%E9%A2%98%EF%BC%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1998487%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%E6%88%91%E8%87%AA%E5%B7%B1%E8%A7%A3%E5%86%B3%E4%BA%86%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E5%B9%B6%E5%88%86%E4%BA%AB%E5%87%BA%E6%9D%A5%E4%BB%A5%E4%BE%9B%E5%B8%AE%E5%8A%A9%E3%80%82%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%E6%88%91%E8%BF%99%E6%A0%B7%E8%AE%BE%E7%BD%AE%20dts%EF%BC%9A%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%E6%8B%B1%2Farm64%2F%E5%90%AF%E5%8A%A8%2Fdts%2F%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%2Ffsl-ls1043a.dtsi%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3Efman0_10g_rx0%EF%BC%9A%E7%AB%AF%E5%8F%A3%4090000%7B%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%20cell-index%20%3D%20%26lt%3B0%26gt%3B%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%E5%85%BC%E5%AE%B9%3D%E2%80%9Cfsl%EF%BC%8Cfman-port-10g-rx%E2%80%9D%EF%BC%9B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Ereg%20%3D%20%26lt%3B0x90000%200x1000%26gt%3B%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%7D%3B%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3Efman0_10g_tx0%EF%BC%9A%E7%AB%AF%E5%8F%A3%40b0000%7B%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%20cell-index%20%3D%20%26lt%3B0%26gt%3B%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%E5%85%BC%E5%AE%B9%3D%E2%80%9Cfsl%EF%BC%8Cfman-port-10g-tx%E2%80%9D%EF%BC%9B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Ereg%20%3D%20%26lt%3B0xb0000%200x1000%26gt%3B%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Efsl%EF%BC%8Cqman%E9%80%9A%E9%81%93id%3D%26lt%3B0x800%26gt%3B%EF%BC%9B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%7D%3B%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3Efm1mac9%3A%20%E4%BB%A5%E5%A4%AA%E7%BD%91%40f0000%20%7B%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%20cell-index%20%3D%20%26lt%3B0%26gt%3B%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%20compatible%20%3D%20%22fsl%2Cfman-memac%22%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Ereg%20%3D%20%26lt%3B0xf0000%200x1000%26gt%3B%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Efsl%EF%BC%8C%E7%AB%AF%E5%8F%A3%E5%8F%A5%E6%9F%84%3D%26lt%3B%26amp%3Bfman0_10g_rx0%26amp%3Bfman0_10g_tx0%26gt%3B%EF%BC%9B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%7D%3B%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3Earch%2Farm64%2Fboot%2Fdts%2Ffreescale%2Ffsl-ls1043a-rdb.dts%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%26amp%3Bfman0%20%7B%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%20ethernet%40e4000%20%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20phy-handle%20%3D%20%26lt%3B%26amp%3Brgmii_phy1%26gt%3B%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Ephy%E8%BF%9E%E6%8E%A5%E7%B1%BB%E5%9E%8B%3D%E2%80%9Crgmii%E2%80%9D%EF%BC%9B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%20%7D%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%20ethernet%40e6000%20%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20phy-handle%20%3D%20%26lt%3B%26amp%3Brgmii_phy2%26gt%3B%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Ephy%E8%BF%9E%E6%8E%A5%E7%B1%BB%E5%9E%8B%3D%E2%80%9Crgmii%E2%80%9D%EF%BC%9B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%20%7D%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%E4%BB%A5%E5%A4%AA%E7%BD%91%40f0000%20%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Ephy%E5%8F%A5%E6%9F%84%3D%26lt%3B%26amp%3Bsgmii_phy1%26gt%3B%EF%BC%9B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Ephy%E8%BF%9E%E6%8E%A5%E7%B1%BB%E5%9E%8B%3D%E2%80%9Csgmii%E2%80%9D%EF%BC%9B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%20%7D%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%20mdio%40fc000%20%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Ergmii_phy1%3A%20%E4%BB%A5%E5%A4%AA%E7%BD%91-phy%400%20%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Ereg%20%3D%20%26lt%3B0x0%26gt%3B%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%7D%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Ergmii_phy2%3A%20%E4%BB%A5%E5%A4%AA%E7%BD%91-phy%401%20%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Ereg%20%3D%20%26lt%3B0x1%26gt%3B%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%7D%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Esgmii_phy1%3A%20%E4%BB%A5%E5%A4%AA%E7%BD%91-phy%403%20%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Ereg%20%3D%20%26lt%3B0x3%26gt%3B%EF%BC%9B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%7D%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%26nbsp%3B%20%7D%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%7D%3B%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%E4%BB%8E%20xfi%20%E6%9B%B4%E6%94%B9%E4%B8%BA%20sgmii%20%E6%97%B6%EF%BC%8C%E9%9C%80%E8%A6%81%E5%B0%86%20SD1_REF_CLK%20%E4%BB%8E%20156MHz%20%E6%9B%B4%E6%94%B9%E4%B8%BA%20125MHz%E3%80%82%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%E6%88%91%E5%9C%A8%20uboot%20%E5%92%8C%20dts%20%E4%B8%AD%E9%87%8D%E7%BD%AE%E4%BA%86%20phy%20%E5%9C%B0%E5%9D%80%E3%80%82%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1997709%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9ALS1043A%20%E4%BB%A5%E5%A4%AA%E7%BD%91%E9%99%84%E5%8A%A0%E9%97%AE%E9%A2%98%EF%BC%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1997709%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%E4%B8%8D%E7%9F%A5%E4%BD%95%E6%95%85%EF%BC%8C%E6%97%A5%E5%BF%97%E8%A2%AB%E6%89%93%E5%8D%B0%E5%87%BA%E6%9D%A5%E4%BA%86%E3%80%82%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%E5%9C%A8u-boot%E4%B8%AD%E8%AF%86%E5%88%AB%E5%A6%82%E4%B8%8B%E3%80%82%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3D%26gt%3B%20mdio%20%E5%88%97%E8%A1%A8%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3EFSL_MDIO0%3A%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E0%20-%20AR8035%20%26lt%3B--%26gt%3B%20FM1%40DTSEC6%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E1%20-%20AR8035%20%26lt%3B--%26gt%3B%20FM1%40DTSEC4%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E3%20-%20AR8031%2FAR8033%20%26lt%3B--%26gt%3B%20FM1%40DTSEC9%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3EFM_TGEC_MDIO%EF%BC%9A%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3D%26gt%3B%20mii%20info%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3EPHY%200x00%EF%BC%9AOUI%20%3D%200x1374%EF%BC%8C%E5%9E%8B%E5%8F%B7%20%3D%200x07%EF%BC%8C%E4%BF%AE%E8%AE%A2%E7%89%88%20%3D%200x02%EF%BC%8C1000baseX%EF%BC%8CHDX%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3EPHY%200x01%EF%BC%9AOUI%20%3D%200x1374%EF%BC%8C%E5%9E%8B%E5%8F%B7%20%3D%200x07%EF%BC%8C%E4%BF%AE%E8%AE%A2%E7%89%88%20%3D%200x02%EF%BC%8C1000baseX%EF%BC%8CHDX%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3EPHY%200x03%EF%BC%9AOUI%20%3D%200x1374%EF%BC%8C%E5%9E%8B%E5%8F%B7%20%3D%200x07%EF%BC%8C%E4%BF%AE%E8%AE%A2%E7%89%88%20%3D%200x04%EF%BC%8C1000baseX%EF%BC%8CFDX%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3D%26gt%3B%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%E5%90%AF%E5%8A%A8%E5%90%8E%EF%BC%8C%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%E5%AE%9E%E4%BE%8B1%EF%BC%9A%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3Edts%E6%96%87%E4%BB%B6%E8%AE%BE%E7%BD%AE%E5%A6%82%E4%B8%8B%EF%BC%9A%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%E6%8B%B1%2Farm64%2F%E5%90%AF%E5%8A%A8%2Fdts%2F%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%2Ffsl-ls1043a.dtsi%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3Efman0%EF%BC%9Afman%401a00000%7B%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E...%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Efman0_rx8%EF%BC%9A%E7%AB%AF%E5%8F%A3%4090000%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Ecell-index%20%3D%20%26lt%3B8%26gt%3B%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%E5%85%BC%E5%AE%B9%3D%E2%80%9Cfsl%EF%BC%8Cfman-port-1g-rx%E2%80%9D%EF%BC%9B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Ereg%20%3D%20%26lt%3B0x90000%200x1000%26gt%3B%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Efman0_tx8%3A%20port%40b0000%20%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Ecell-index%20%3D%20%26lt%3B8%26gt%3B%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%E5%85%BC%E5%AE%B9%3D%E2%80%9Cfsl%EF%BC%8Cfman-port-1g-tx%E2%80%9D%EF%BC%9B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Ereg%20%3D%20%26lt%3B0xb0000%200x1000%26gt%3B%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Efm1mac9%3A%20%E4%BB%A5%E5%A4%AA%E7%BD%91%40f0000%20%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Ecell-index%20%3D%20%26lt%3B8%26gt%3B%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Ecompatible%20%3D%20%22fsl%2Cfman-memac%22%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Ereg%20%3D%20%26lt%3B0xf0000%200x1000%26gt%3B%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Efsl%2Cport-handles%20%3D%20%26lt%3B%26amp%3Bfman0_rx8%20%26amp%3Bfman0_tx8%26gt%3B%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E...%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%7D%3B%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3Earch%2Farm64%2Fboot%2Fdts%2Ffreescale%2Ffsl-ls1043a-rdb.dts%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%26amp%3Bfman0%20%7B%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Eethernet%40e4000%20%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%E7%8A%B6%E6%80%81%20%3D%20%E2%80%9C%E5%A5%BD%E7%9A%84%E2%80%9D%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Ephy-handle%20%3D%20%26lt%3B%26amp%3Brgmii_phy1%26gt%3B%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Ephy%E8%BF%9E%E6%8E%A5%E7%B1%BB%E5%9E%8B%3D%E2%80%9Crgmii%E2%80%9D%EF%BC%9B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Eethernet%40e6000%20%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%E7%8A%B6%E6%80%81%20%3D%20%E2%80%9C%E5%A5%BD%E7%9A%84%E2%80%9D%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Ephy-handle%20%3D%20%26lt%3B%26amp%3Brgmii_phy2%26gt%3B%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Ephy%E8%BF%9E%E6%8E%A5%E7%B1%BB%E5%9E%8B%3D%E2%80%9Crgmii%E2%80%9D%EF%BC%9B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%E4%BB%A5%E5%A4%AA%E7%BD%91%40f0000%20%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%E7%8A%B6%E6%80%81%20%3D%20%E2%80%9C%E5%A5%BD%E7%9A%84%E2%80%9D%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Ephy%E5%8F%A5%E6%9F%84%3D%26lt%3B%26amp%3Bsgmii_phy1%26gt%3B%EF%BC%9B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Ephy%E8%BF%9E%E6%8E%A5%E7%B1%BB%E5%9E%8B%3D%E2%80%9Csgmii%E2%80%9D%EF%BC%9B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Emdio%40fc000%20%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Ergmii_phy1%3A%20%E4%BB%A5%E5%A4%AA%E7%BD%91-phy%401%20%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Ereg%20%3D%20%26lt%3B0x1%26gt%3B%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Ergmii_phy2%EF%BC%9A%E4%BB%A5%E5%A4%AA%E7%BD%91-phy%402%20%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Ereg%20%3D%20%26lt%3B0x2%26gt%3B%EF%BC%9B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Esgmii_phy1%3A%20%E4%BB%A5%E5%A4%AA%E7%BD%91-phy%403%20%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Ereg%20%3D%20%26lt%3B0x3%26gt%3B%EF%BC%9B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%7D%3B%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%E6%88%91%E7%94%A8%20ifconfig%20-a%20%E6%A3%80%E6%9F%A5%E8%BF%87%EF%BC%8Cfm1-mac9%20%E6%A0%B9%E6%9C%AC%E7%9C%8B%E4%B8%8D%E8%A7%81%E3%80%82%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3Eroot%40ls1043ardb%3A~%23%20ifconfig%20-a%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3Efm1-mac3%20%E9%93%BE%E8%B7%AF%E5%B0%81%E8%A3%85%EF%BC%9A%E4%BB%A5%E5%A4%AA%E7%BD%91%20HWaddr%20fc%3Ac2%3A3d%3A31%3A76%3A54%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%E5%B9%BF%E6%92%AD%E5%A4%9A%E6%92%AD%20MTU%3A1500%20%E6%8C%87%E6%A0%87%3A1%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3ERX%20%E6%95%B0%E6%8D%AE%E5%8C%85%EF%BC%9A0%20%E9%94%99%E8%AF%AF%EF%BC%9A0%20%E4%B8%A2%E5%BC%83%EF%BC%9A0%20%E6%BA%A2%E5%87%BA%EF%BC%9A0%20%E5%B8%A7%EF%BC%9A0%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3ETX%20%E6%95%B0%E6%8D%AE%E5%8C%85%EF%BC%9A0%20%E9%94%99%E8%AF%AF%EF%BC%9A0%20%E4%B8%A2%E5%BC%83%EF%BC%9A0%20%E8%B6%85%E9%99%90%EF%BC%9A0%20%E8%BD%BD%E6%B3%A2%EF%BC%9A0%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20collisions%3A0%20txqueuelen%3A1000%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3ERX%20%E5%AD%97%E8%8A%82%EF%BC%9A0%20(0.0%20B)%20TX%20%E5%AD%97%E8%8A%82%EF%BC%9A0%20(0.0%20B)%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20Memory%3A1ae4000-1ae4fff%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3Efm1-mac4%20%E9%93%BE%E8%B7%AF%E5%B0%81%E8%A3%85%EF%BC%9A%E4%BB%A5%E5%A4%AA%E7%BD%91%20HWaddr%2000%3A04%3A9f%3A04%3A4d%3Ae2%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%E5%B9%BF%E6%92%AD%E5%A4%9A%E6%92%AD%20MTU%3A1500%20%E6%8C%87%E6%A0%87%3A1%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3ERX%20%E6%95%B0%E6%8D%AE%E5%8C%85%EF%BC%9A0%20%E9%94%99%E8%AF%AF%EF%BC%9A0%20%E4%B8%A2%E5%BC%83%EF%BC%9A0%20%E6%BA%A2%E5%87%BA%EF%BC%9A0%20%E5%B8%A7%EF%BC%9A0%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3ETX%20%E6%95%B0%E6%8D%AE%E5%8C%85%EF%BC%9A0%20%E9%94%99%E8%AF%AF%EF%BC%9A0%20%E4%B8%A2%E5%BC%83%EF%BC%9A0%20%E8%B6%85%E9%99%90%EF%BC%9A0%20%E8%BD%BD%E6%B3%A2%EF%BC%9A0%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20collisions%3A0%20txqueuelen%3A1000%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3ERX%20%E5%AD%97%E8%8A%82%EF%BC%9A0%20(0.0%20B)%20TX%20%E5%AD%97%E8%8A%82%EF%BC%9A0%20(0.0%20B)%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20Memory%3A1ae6000-1ae6fff%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3Eroot%40ls1043ardb%3A~%23%20dmesg%20%7C%20grep%20fm1%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%5B4.458930%5Dfsl_dpa%20fsl%2Cdpaa%3Aethernet%402%20fm1-mac3%3A%E4%BB%8Eeth0%E9%87%8D%E5%91%BD%E5%90%8D%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%5B4.519680%5Dudevd%5B1353%5D%3A%20%E5%B0%86%E7%BD%91%E7%BB%9C%E6%8E%A5%E5%8F%A3%20eth0%20%E9%87%8D%E5%91%BD%E5%90%8D%E4%B8%BA%20fm1-mac3%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%5B4.526057%5Dfsl_dpa%20fsl%2Cdpaa%3Aethernet%403%20fm1-mac4%3A%E4%BB%8Eeth1%E9%87%8D%E5%91%BD%E5%90%8D%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%5B4.669416%5Dudevd%5B1354%5D%3A%20%E5%B0%86%E7%BD%91%E7%BB%9C%E6%8E%A5%E5%8F%A3%20eth1%20%E9%87%8D%E5%91%BD%E5%90%8D%E4%B8%BA%20fm1-mac4%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3Eroot%40ls1043ardb%3A~%23%20uname%20-a%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3ELinux%20ls1043ardb%204.1.35-rt41%2316%20SMP%202022%20%E5%B9%B4%2011%20%E6%9C%88%208%20%E6%97%A5%E6%98%9F%E6%9C%9F%E4%BA%8C%2019%3A14%3A01%20KST%20aarch64%20GNU%2FLinux%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%E5%AE%9E%E4%BE%8B2%EF%BC%9A%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3Edts%E6%96%87%E4%BB%B6%E8%AE%BE%E7%BD%AE%E5%A6%82%E4%B8%8B%EF%BC%9A%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%E6%8B%B1%2Farm64%2F%E5%90%AF%E5%8A%A8%2Fdts%2F%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%2Ffsl-ls1043a.dtsi%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3Efman0%EF%BC%9Afman%401a00000%7B%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E...%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Efman0_10g_rx0%EF%BC%9A%E7%AB%AF%E5%8F%A3%4090000%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Ecell-index%20%3D%20%26lt%3B0%26gt%3B%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%E5%85%BC%E5%AE%B9%3D%E2%80%9Cfsl%EF%BC%8Cfman-port-10g-rx%E2%80%9D%EF%BC%9B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Ereg%20%3D%20%26lt%3B0x90000%200x1000%26gt%3B%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Efman0_10g_tx0%EF%BC%9A%E7%AB%AF%E5%8F%A3%40b0000%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Ecell-index%20%3D%20%26lt%3B0%26gt%3B%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%E5%85%BC%E5%AE%B9%3D%E2%80%9Cfsl%EF%BC%8Cfman-port-10g-tx%E2%80%9D%EF%BC%9B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Ereg%20%3D%20%26lt%3B0xb0000%200x1000%26gt%3B%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Efsl%EF%BC%8Cqman%E9%80%9A%E9%81%93id%3D%26lt%3B0x800%26gt%3B%EF%BC%9B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Efm1mac9%3A%20%E4%BB%A5%E5%A4%AA%E7%BD%91%40f0000%20%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Ecell-index%20%3D%20%26lt%3B0%26gt%3B%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Ecompatible%20%3D%20%22fsl%2Cfman-memac%22%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Ereg%20%3D%20%26lt%3B0xf0000%200x1000%26gt%3B%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Efsl%EF%BC%8C%E7%AB%AF%E5%8F%A3%E5%8F%A5%E6%9F%84%3D%26lt%3B%26amp%3Bfman0_10g_rx0%26amp%3Bfman0_10g_tx0%26gt%3B%EF%BC%9B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E...%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%7D%3B%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3Earch%2Farm64%2Fboot%2Fdts%2Ffreescale%2Ffsl-ls1043a-rdb.dts%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%26amp%3Bfman0%20%7B%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Eethernet%40e4000%20%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%E7%8A%B6%E6%80%81%20%3D%20%E2%80%9C%E5%A5%BD%E7%9A%84%E2%80%9D%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Ephy-handle%20%3D%20%26lt%3B%26amp%3Brgmii_phy1%26gt%3B%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Ephy%E8%BF%9E%E6%8E%A5%E7%B1%BB%E5%9E%8B%3D%E2%80%9Crgmii%E2%80%9D%EF%BC%9B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Eethernet%40e6000%20%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%E7%8A%B6%E6%80%81%20%3D%20%E2%80%9C%E5%A5%BD%E7%9A%84%E2%80%9D%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Ephy-handle%20%3D%20%26lt%3B%26amp%3Brgmii_phy2%26gt%3B%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Ephy%E8%BF%9E%E6%8E%A5%E7%B1%BB%E5%9E%8B%3D%E2%80%9Crgmii%E2%80%9D%EF%BC%9B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%E4%BB%A5%E5%A4%AA%E7%BD%91%40f0000%20%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Ephy%E8%BF%9E%E6%8E%A5%E7%B1%BB%E5%9E%8B%3D%E2%80%9Csgmii%E2%80%9D%EF%BC%9B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%E5%9B%BA%E5%AE%9A%E9%93%BE%E6%8E%A5%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%E9%80%9F%E5%BA%A6%3D%26lt%3B1000%26gt%3B%EF%BC%9B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%E5%85%A8%E5%8F%8C%E5%B7%A5%EF%BC%9B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Emdio%40fc000%20%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Ergmii_phy1%3A%20%E4%BB%A5%E5%A4%AA%E7%BD%91-phy%401%20%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Ereg%20%3D%20%26lt%3B0x1%26gt%3B%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Ergmii_phy2%EF%BC%9A%E4%BB%A5%E5%A4%AA%E7%BD%91-phy%402%20%7B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Ereg%20%3D%20%26lt%3B0x2%26gt%3B%EF%BC%9B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%7D%3B%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%E8%BF%99%E6%AC%A1%E6%88%91%E5%8F%AF%E4%BB%A5%E7%9C%8B%E5%88%B0%20fm1-mac9%EF%BC%8C%E4%BD%86%E6%98%AF%E6%97%A0%E6%B3%95%20ping%20%E9%80%9A%E5%AE%83%E3%80%82%E5%85%B6%E4%BB%96%E5%B7%A5%E4%BD%9C%E6%AD%A3%E5%B8%B8%E7%9A%84%E7%AB%AF%E5%8F%A3%E4%B9%9F%E6%97%A0%E6%B3%95%20ping%20%E9%80%9A%E3%80%82%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3Eroot%40ls1043ardb%3A~%23%20ifconfig%20-a%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3Efm1-mac3%20%E9%93%BE%E8%B7%AF%E5%B0%81%E8%A3%85%EF%BC%9A%E4%BB%A5%E5%A4%AA%E7%BD%91%20HWaddr%20fc%3Ac2%3A3d%3A31%3A76%3A54%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%E5%B9%BF%E6%92%AD%E5%A4%9A%E6%92%AD%20MTU%3A1500%20%E6%8C%87%E6%A0%87%3A1%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3ERX%20%E6%95%B0%E6%8D%AE%E5%8C%85%EF%BC%9A0%20%E9%94%99%E8%AF%AF%EF%BC%9A0%20%E4%B8%A2%E5%BC%83%EF%BC%9A0%20%E6%BA%A2%E5%87%BA%EF%BC%9A0%20%E5%B8%A7%EF%BC%9A0%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3ETX%20%E6%95%B0%E6%8D%AE%E5%8C%85%EF%BC%9A0%20%E9%94%99%E8%AF%AF%EF%BC%9A0%20%E4%B8%A2%E5%BC%83%EF%BC%9A0%20%E8%B6%85%E9%99%90%EF%BC%9A0%20%E8%BD%BD%E6%B3%A2%EF%BC%9A0%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20collisions%3A0%20txqueuelen%3A1000%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3ERX%20%E5%AD%97%E8%8A%82%EF%BC%9A0%20(0.0%20B)%20TX%20%E5%AD%97%E8%8A%82%EF%BC%9A0%20(0.0%20B)%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20Memory%3A1ae4000-1ae4fff%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3Efm1-mac4%20%E9%93%BE%E8%B7%AF%E5%B0%81%E8%A3%85%EF%BC%9A%E4%BB%A5%E5%A4%AA%E7%BD%91%20HWaddr%2000%3A04%3A9f%3A04%3A4d%3Ae2%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%E5%B9%BF%E6%92%AD%E5%A4%9A%E6%92%AD%20MTU%3A1500%20%E6%8C%87%E6%A0%87%3A1%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3ERX%20%E6%95%B0%E6%8D%AE%E5%8C%85%EF%BC%9A0%20%E9%94%99%E8%AF%AF%EF%BC%9A0%20%E4%B8%A2%E5%BC%83%EF%BC%9A0%20%E6%BA%A2%E5%87%BA%EF%BC%9A0%20%E5%B8%A7%EF%BC%9A0%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3ETX%20%E6%95%B0%E6%8D%AE%E5%8C%85%EF%BC%9A0%20%E9%94%99%E8%AF%AF%EF%BC%9A0%20%E4%B8%A2%E5%BC%83%EF%BC%9A0%20%E8%B6%85%E9%99%90%EF%BC%9A0%20%E8%BD%BD%E6%B3%A2%EF%BC%9A0%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20collisions%3A0%20txqueuelen%3A1000%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3ERX%20%E5%AD%97%E8%8A%82%EF%BC%9A0%20(0.0%20B)%20TX%20%E5%AD%97%E8%8A%82%EF%BC%9A0%20(0.0%20B)%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20Memory%3A1ae6000-1ae6fff%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3Efm1-mac9%20%E9%93%BE%E8%B7%AF%E5%B0%81%E8%A3%85%EF%BC%9A%E4%BB%A5%E5%A4%AA%E7%BD%91%20HWaddr%2000%3A04%3A9f%3A04%3A4d%3Ae5%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%E5%B9%BF%E6%92%AD%E5%A4%9A%E6%92%AD%20MTU%3A1500%20%E6%8C%87%E6%A0%87%3A1%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3ERX%20%E6%95%B0%E6%8D%AE%E5%8C%85%EF%BC%9A0%20%E9%94%99%E8%AF%AF%EF%BC%9A0%20%E4%B8%A2%E5%BC%83%EF%BC%9A0%20%E6%BA%A2%E5%87%BA%EF%BC%9A0%20%E5%B8%A7%EF%BC%9A0%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3ETX%20%E6%95%B0%E6%8D%AE%E5%8C%85%EF%BC%9A0%20%E9%94%99%E8%AF%AF%EF%BC%9A0%20%E4%B8%A2%E5%BC%83%EF%BC%9A0%20%E8%B6%85%E9%99%90%EF%BC%9A0%20%E8%BD%BD%E6%B3%A2%EF%BC%9A0%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20collisions%3A0%20txqueuelen%3A1000%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3ERX%20%E5%AD%97%E8%8A%82%EF%BC%9A0%20(0.0%20B)%20TX%20%E5%AD%97%E8%8A%82%EF%BC%9A0%20(0.0%20B)%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20Memory%3A1af0000-1af0fff%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3Eroot%40ls1043ardb%3A~%23%20ifconfig%20fm1-mac9%20192.168.0.100%2F16%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3Eroot%40ls1043ardb%3A~%23%20ping%20192.168.20.10%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3EPING%20192.168.20.10%20(192.168.20.10)56%EF%BC%8884%EF%BC%89%E5%AD%97%E8%8A%82%E7%9A%84%E6%95%B0%E6%8D%AE%E3%80%82%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%E6%9D%A5%E8%87%AA%20192.168.0.100%20icmp_seq%3D1%20%E7%9B%AE%E6%A0%87%E4%B8%BB%E6%9C%BA%E4%B8%8D%E5%8F%AF%E8%BE%BE%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%E6%9D%A5%E8%87%AA%20192.168.0.100%20icmp_seq%3D2%20%E7%9B%AE%E6%A0%87%E4%B8%BB%E6%9C%BA%E4%B8%8D%E5%8F%AF%E8%BE%BE%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%E6%9D%A5%E8%87%AA%20192.168.0.100%20icmp_seq%3D3%20%E7%9B%AE%E6%A0%87%E4%B8%BB%E6%9C%BA%E4%B8%8D%E5%8F%AF%E8%BE%BE%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%5EC%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E---%20192.168.20.10%20ping%E7%BB%9F%E8%AE%A1---%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%E5%8F%91%E9%80%81%E4%BA%86%204%20%E4%B8%AA%E6%95%B0%E6%8D%AE%E5%8C%85%EF%BC%8C%E6%8E%A5%E6%94%B6%E4%BA%86%200%20%E4%B8%AA%E6%95%B0%E6%8D%AE%E5%8C%85%EF%BC%8C%2B3%20%E4%B8%AA%E9%94%99%E8%AF%AF%EF%BC%8C100%25%20%E6%95%B0%E6%8D%AE%E5%8C%85%E4%B8%A2%E5%A4%B1%EF%BC%8C%E8%80%97%E6%97%B6%203000%20%E6%AF%AB%E7%A7%92%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%E7%AE%A1%E9%81%93%203%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3Eroot%40ls1043ardb%3A~%23%20dmesg%20%7C%20grep%20fm1%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%5B4.455602%5Dfsl_dpa%20fsl%2Cdpaa%3Aethernet%402%20fm1-mac3%3A%E4%BB%8Eeth0%E9%87%8D%E5%91%BD%E5%90%8D%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%5B4.549437%5Dudevd%5B1494%5D%3A%20%E5%B0%86%E7%BD%91%E7%BB%9C%E6%8E%A5%E5%8F%A3%20eth0%20%E9%87%8D%E5%91%BD%E5%90%8D%E4%B8%BA%20fm1-mac3%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%5B4.549772%5Dfsl_dpa%20fsl%2Cdpaa%3Aethernet%408%20fm1-mac9%3A%E4%BB%8Eeth2%E9%87%8D%E5%91%BD%E5%90%8D%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%5B4.629395%5Dudevd%5B1497%5D%3A%20%E5%B0%86%E7%BD%91%E7%BB%9C%E6%8E%A5%E5%8F%A3%20eth2%20%E9%87%8D%E5%91%BD%E5%90%8D%E4%B8%BA%20fm1-mac9%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%5B4.631714%5Dfsl_dpa%20fsl%2Cdpaa%3Aethernet%403%20fm1-mac4%3A%E4%BB%8Eeth1%E9%87%8D%E5%91%BD%E5%90%8D%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%5B4.719371%5Dudevd%5B1495%5D%3A%20%E5%B0%86%E7%BD%91%E7%BB%9C%E6%8E%A5%E5%8F%A3%20eth1%20%E9%87%8D%E5%91%BD%E5%90%8D%E4%B8%BA%20fm1-mac4%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3Eroot%40ls1043ardb%3A~%23%20ifconfig%20fm1-mac9%20down%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%5B174.695225%5DCPU%200%3A%26gt%3B%E8%AD%A6%E5%91%8A%EF%BC%88FM%E7%AB%AF%E5%8F%A3%EF%BC%89%5BCPU00%EF%BC%8C%2Fhome%2Fyhoh%2Fwk-qoriqSDKv2-1703%2FqoriqSDKv2-1703_dru100_V1_180316%2Fbuild_ls1043ardb%2Ftmp%2Fwork-shared%2Fls1043ardb%2Fkernel-source%2Fdrivers%2Fnet%2Fethernet%2Ffreescale%2Fsdk_fman%2FPeripherals%2FFM%2FPort%2Ffm_port.c%3A3547FM_PORT_Disable%EF%BC%9A%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%5B174.718163%5Dcpu%200%EF%BC%9AFM-0-port-10g-TX-0%EF%BC%9ABMI%20%E6%88%96%20QMI%20%E6%AD%A3%E5%BF%99%E3%80%82%E7%AB%AF%E5%8F%A3%E8%A2%AB%E8%BF%AB%E5%85%B3%E9%97%AD%5B174.725120%5DCPU%200%EF%BC%9A%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3Eroot%40ls1043ardb%3A~%23%20ifconfig%20fm1-mac3%20192.168.0.100%2F16%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3Eroot%40ls1043ardb%3A~%23%20ping%20192.168.20.10%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3EPING%20192.168.20.10%20(192.168.20.10)56%EF%BC%8884%EF%BC%89%E5%AD%97%E8%8A%82%E7%9A%84%E6%95%B0%E6%8D%AE%E3%80%82%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%E6%9D%A5%E8%87%AA%20192.168.0.100%20icmp_seq%3D1%20%E7%9B%AE%E6%A0%87%E4%B8%BB%E6%9C%BA%E4%B8%8D%E5%8F%AF%E8%BE%BE%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%E6%9D%A5%E8%87%AA%20192.168.0.100%20icmp_seq%3D2%20%E7%9B%AE%E6%A0%87%E4%B8%BB%E6%9C%BA%E4%B8%8D%E5%8F%AF%E8%BE%BE%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%E6%9D%A5%E8%87%AA%20192.168.0.100%20icmp_seq%3D3%20%E7%9B%AE%E6%A0%87%E4%B8%BB%E6%9C%BA%E4%B8%8D%E5%8F%AF%E8%BE%BE%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%5EC%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E---%20192.168.20.10%20ping%E7%BB%9F%E8%AE%A1---%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%E5%8F%91%E9%80%81%E4%BA%86%206%20%E4%B8%AA%E6%95%B0%E6%8D%AE%E5%8C%85%EF%BC%8C%E6%8E%A5%E6%94%B6%E4%BA%86%200%20%E4%B8%AA%E6%95%B0%E6%8D%AE%E5%8C%85%EF%BC%8C%2B3%20%E4%B8%AA%E9%94%99%E8%AF%AF%EF%BC%8C100%25%20%E6%95%B0%E6%8D%AE%E5%8C%85%E4%B8%A2%E5%A4%B1%EF%BC%8C%E8%80%97%E6%97%B6%205008%20%E6%AF%AB%E7%A7%92%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%E7%AE%A1%E9%81%93%203%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3Eroot%40ls1043ardb%3A~%23%20ifconfig%20fm1-mac3%20down%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3Eroot%40ls1043ardb%3A~%23%20ifconfig%20fm1-mac4%20192.168.0.100%2F16%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%5B267.330310%5Dfsl_dpa%20fsl%EF%BC%8Cdpaa%3Aethernet%403%20fm1-mac4%3A%E6%97%A0%E6%B3%95%E8%BF%9E%E6%8E%A5%E5%88%B0PHY%2Fsoc%2Ffman%401a00000%2Fmdio%40fc000%2Fethernet-phy%402%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%5B267.341016%5Dfsl_dpa%20fsl%EF%BC%8Cdpaa%3A%E4%BB%A5%E5%A4%AA%E7%BD%91%403%20fm1-mac4%3A%20init_phy%EF%BC%88%EF%BC%89%3D-19%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3ESIOCSIFFLAGS%EF%BC%9A%E6%B2%A1%E6%9C%89%E8%BF%99%E6%A0%B7%E7%9A%84%E8%AE%BE%E5%A4%87%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CA%20href%3D%22mailto%3Aroot%40ls1043ardb%3A~%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Eroot%40ls1043ardb%3A~%23%3C%2FA%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%E6%9C%89%E4%BB%80%E4%B9%88%E9%97%AE%E9%A2%98%EF%BC%9F%E6%88%91%E9%9C%80%E8%A6%81%E5%B8%AE%E5%8A%A9%E3%80%82%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%E8%B0%A2%E8%B0%A2%E4%BD%A0%EF%BC%8C%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3EGyosun.%3C%2FFONT%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E
