working with pwm channels - mc9s08sh32
1,672件の閲覧回数
shany
I'm working on MCU - mc9s08sh32 and I want to operate 3 pwm channels - PTA6_TPM2CH0, PTB5_TPM1CH1, PTA7_TPM2CH1.
My problem is with the first and last channels ( PTA6 + PTA7 ) - they have a shared counter (TPM2) and I don't really know how to control their pwm ratio. When I enable both of them - each with different pwm ratios - one of them is off and sometimes there is some pwm ratio but I don't know how to predict it.
Does anybody have an idea what to do?
Does anybody have a sample project with these pwm channels?
shany
タグ(1)
3 返答(返信)
1,436件の閲覧回数
ProcessorExpert
Senior Contributor III
I am not aware of such issue with PWM component. However could you please share here your project including more detailed description.
best regards
Vojtech Filip
Processor Expert Support Team
1,436件の閲覧回数
shany
Here's a more detailed description of my problem -
When I try to activate all 3 pwm channels on 100% ratio - the code is :
pwm1_SetRatio8(0);
pwm2_SetRatio8 (0);
pwm3_SetRatio8 (0);
 pwm1_Enable();
 pwm2_Enable();
 pwm3_Enable();
however, the outcome is sometimes correct - meaning that all 3 pwm channels are on 100% ratio, and in other times the outcome is that only pwm1+2 are on 100% ratio while pwm3 is off completely  (pwm2 + 3 are the ones with the shared counter, as I mentioned in the previous message).
Another problem - when I perform  the following code -
pwm1_SetRatio8(255);
pwm2_SetRatio8 (25);
 pwm3_SetRatio8 (200);
pwm1_Disable();
pwm2_Enable();
pwm3_Enable();
again, the outcome is sometimes correct and in other times pwm2 + pwm 3 are on 100% and not in the required pulse ratio.
I hope there are enough details here... please tell me if you need further information.
Thanks alot,
Shany
1,436件の閲覧回数
ProcessorExpert
as I wrote before. Could you please post here your project? Please note that it will significantly reduce my time on your issue.
best regards
Vojtech Filip
