I'm working on MCU - mc9s08sh32 and I want to operate 3 pwm channels - PTA6_TPM2CH0, PTB5_TPM1CH1, PTA7_TPM2CH1.
My problem is with the first and last channels ( PTA6 + PTA7 ) - they have a shared counter (TPM2) and I don't really know how to control their pwm ratio. When I enable both of them - each with different pwm ratios - one of them is off and sometimes there is some pwm ratio but I don't know how to predict it.
Does anybody have an idea what to do?
Does anybody have a sample project with these pwm channels?
shany
I am not aware of such issue with PWM component. However could you please share here your project including more detailed description.
best regards
Vojtech Filip
Processor Expert Support Team
Here's a more detailed description of my problem -
When I try to activate all 3 pwm channels on 100% ratio - the code is :
pwm1_SetRatio8(0);
pwm2_SetRatio8 (0);
pwm3_SetRatio8 (0);
 pwm1_Enable();
 pwm2_Enable();
 pwm3_Enable();
however, the outcome is sometimes correct - meaning that all 3 pwm channels are on 100% ratio, and in other times the outcome is that only pwm1+2 are on 100% ratio while pwm3 is off completely (pwm2 + 3 are the ones with the shared counter, as I mentioned in the previous message).
Another problem - when I perform the following code -
pwm1_SetRatio8(255);
pwm2_SetRatio8 (25);
 pwm3_SetRatio8 (200);
pwm1_Disable();
pwm2_Enable();
pwm3_Enable();
again, the outcome is sometimes correct and in other times pwm2 + pwm 3 are on 100% and not in the required pulse ratio.
I hope there are enough details here... please tell me if you need further information.
Thanks alot,
Shany
as I wrote before. Could you please post here your project? Please note that it will significantly reduce my time on your issue.
best regards
Vojtech Filip
