why PLLCKEN is disabled in PE generated code?
3,840 次查看
another_bug
why the generated code doesn't enable PLLCKEN?
3,669 次查看
ProcessorExpert
Senior Contributor III
I was informed that setting PLLCLKEN is necessary only when MCG is in FLL enabled mode. If it's in PLL enabled mode, the PLL is already running and the PLLCLKEN has no influence.
best regards
Petr Hradsky
Processor Expert Support Team
4 回复数
3,669 次查看
ProcessorExpert
Could you please give us more information on:
- What CPU du you use
- What  version of software (CodeWarrior) etc..
Or a  project demontrating the problem would be also helpful.
best regards
Petr Hradsky
3,669 次查看
another_bug
MK20DN512VMD10
cw10.2
WIN7-64
3,669 次查看
another_bug
10MHZ Crystal. RTC disabled
3,670 次查看
ProcessorExpert
best regards
Petr Hradsky
