why PLLCKEN is disabled in PE generated code?
3,724件の閲覧回数
another_bug
why the generated code doesn't enable PLLCKEN?
3,553件の閲覧回数
ProcessorExpert
Senior Contributor III
I was informed that setting PLLCLKEN is necessary only when MCG is in FLL enabled mode. If it's in PLL enabled mode, the PLL is already running and the PLLCLKEN has no influence.
best regards
Petr Hradsky
Processor Expert Support Team
4 返答(返信)
3,553件の閲覧回数
ProcessorExpert
Could you please give us more information on:
- What CPU du you use
- What  version of software (CodeWarrior) etc..
Or a  project demontrating the problem would be also helpful.
best regards
Petr Hradsky
3,553件の閲覧回数
another_bug
MK20DN512VMD10
cw10.2
WIN7-64
3,553件の閲覧回数
another_bug
10MHZ Crystal. RTC disabled
3,554件の閲覧回数
ProcessorExpert
best regards
Petr Hradsky
