real-time-edge build for i.MX93-EVK extensible SDK build fails
3,037件の閲覧回数
Z2025121
real-time-edge v2.9 for i.MX93-EVK
"bitbake nxp-image-real-time-edge" finished successfully
"bitbake nxp-image-real-time-edge -c populate_sdk_ext" fails
extensible SDK fails:
ERROR: The file /usr/include/ecrt.h is installed by both igh-ethercat and igh-ethercat-userspace, aborting
Any idea to fix the issue?
3 返答(返信)
2,948件の閲覧回数
Z2025121
Normal SDK does not have any build issue. But the extensible SDK "bitbake nxp-image-real-time-edge -c populate_sdk_ext"
fails because of a dependency issue: "/usr/include/ecrt.h is installed by both igh-ethercat and igh-ethercat-userspace". Is there any fix or workaround for the issue?
Many thanks.
3,015件の閲覧回数
AldoG
Have you tried using normal SDK first?
Does it have the same issues?
Best regards/Saludos,
Aldo.
2,999件の閲覧回数
Z2025121
The normal SDK does not have this build issue.
