i.MX RT1052 - Will we get another nested ISR within an ISR?
3,514 次查看
Cindy
My question is will we ever get a nested ISR within an IRQ Handler?
In other words, whenever an interrupt is triggered, its ISR(interrupt service routine) will be called. Let say this IRQ handler is GPT2_IRQHandler. While processing this ISR, will another interrupt of higher priority is being triggered and its ISR being called being exiting GPT2_IRQHandler?
Thank you.
Cindy
标记 (2)
3,507 次查看
ErichStyger
Specialist I
Hi @Cindy ,
short answer: yes.
longer answer: see https://mcuoneclipse.com/tag/nvic/
The RT1052 is an ARM Cortex-M7 and features the NVIC (Nested Vectored Interrupt controller): so if inside an interrupt there is another interrupt getting pending with higher urgency, it will interrrupt that interrupt.
I hope this helps,
Erich
3,500 次查看
Cindy
Hi Erich,
Thank you for your prompt reply and the link to the very useful articles that have answered all my queries about the interrupt.
Cindy
3,508 次查看
ErichStyger
Specialist I
Hi @Cindy ,
short answer: yes.
I hope this helps,
Erich
