My question is will we ever get a nested ISR within an IRQ Handler?
In other words, whenever an interrupt is triggered, its ISR(interrupt service routine) will be called. Let say this IRQ handler is GPT2_IRQHandler. While processing this ISR, will another interrupt of higher priority is being triggered and its ISR being called being exiting GPT2_IRQHandler?
Thank you.
Cindy
已解决! 转到解答。
Hi @Cindy ,
short answer: yes.
longer answer: see https://mcuoneclipse.com/tag/nvic/
The RT1052 is an ARM Cortex-M7 and features the NVIC (Nested Vectored Interrupt controller): so if inside an interrupt there is another interrupt getting pending with higher urgency, it will interrrupt that interrupt.
I hope this helps,
Erich
Hi @Cindy ,
short answer: yes.
I hope this helps,
Erich
