how to add another baud rate on one UART
swatikhade
if we have select  Uart component ,in that we have take different baudrates.so how to initialize different different baud rate through component?
vfilip
I assume you are using Serial_LDD. In this case just select "list of values" in Timing dialog. There is also associated SelectBaudRate function to update the communication speed in run-time.
best regards
Vojtech Filip
