code bugs in FLASH_LDD
1,629件の閲覧回数
bowerymarc
another cast bug which while only warns in C, is fatal in C++.  In the generated code file we get the error:
../Generated_Code/IntFlashLdd1.c: In function 'LDD_TError IntFlashLdd1_Write(LDD_TDeviceData*, LDD_TData*, LDD_FLASH_TAddress, LDD_FLASH_TDataSize)':
../Generated_Code/IntFlashLdd1.c:253:35: error: invalid conversion from 'LDD_TData* {aka void*}' to 'std::uint8_t* {aka unsigned char*}' [-fpermissive]
mingw32-make: *** [Generated_Code/IntFlashLdd1.o] Error 1
Which again can be fixed by properly casting the assignment.
1,473件の閲覧回数
vfilip
I have reproduce it, we will fix it for next release.
Vojtech Filip
Processor Expert Support Team
1,474件の閲覧回数
vfilip
Vojtech Filip
