bug in MKL04Z16VFK4 CPU component?
bowerymarc
It looks like the memory size and range is incorrect in then CPU component for MKL04Z16VFK4.  The '8 and '32 seem OK.
With this setting, programs loading get a Hard Fault within __copy_rom_sections_to_ram()
Changing address to 1FFFFE00 and size to 800 (which matches the screwy data sheet formula, and the actual amount of SRAM on the chip) and the fault goes away.
M
Petr_H
I confirm that it's a bug in Processor Expert. We will fix it for the next Processor Expert release. You have correctly identified the workaround.
We are sorry for the inconvenience.
Petr Hradsky
Processor Expert Support Team
Petr_H
Petr Hradsky
