Unable to use capture driver in Codewarrior 10.3
ソリューションへジャンプ
3,910件の閲覧回数
prajnithkumar
Hi everyone,
I'm trying to capture analog signal , so I'm trying to set up capture driver available in processor expert . I'm using codewarrior 10.3 with MQX lite for Kinetis K21 series of Microcontroller.
After adding CAPTURE driver when i try to select the Referenced conponents as Capture_LDD , its automcatically getting deselected.
I have already added a TU1:TimerUnit_LDD in the project.
Do i have to added any other component to used capture_ldd driver
Thanks & Regards
Prajnith
3,771件の閲覧回数
vfilip
Capture_LDD is not supported yet. It should not be available in Components Library. Please use TimerUnit_LDD instead.
best regards
Vojtech Filip
Processor Expert Support Team
3 返答(返信)
3,772件の閲覧回数
vfilip
best regards
Vojtech Filip
3,771件の閲覧回数
prajnithkumar
Can you please tell me when it will be available.
3,771件の閲覧回数
vfilip
the Capture_LDD should not be listed in component Library - it is a bug in current version. It should be fixed for next release.
Regarding Capture_LDD - I have got info the this component should be published in beginning of Q4 (probably within CW V10.5)
best regards
Vojtech Filip
