Unable to use capture driver in Codewarrior 10.3
3,897 次查看
prajnithkumar
Hi everyone,
I'm trying to capture analog signal , so I'm trying to set up capture driver available in processor expert . I'm using codewarrior 10.3 with MQX lite for Kinetis K21 series of Microcontroller.
After adding CAPTURE driver when i try to select the Referenced conponents as Capture_LDD , its automcatically getting deselected.
I have already added a TU1:TimerUnit_LDD in the project.
Do i have to added any other component to used capture_ldd driver
Thanks & Regards
Prajnith
3,758 次查看
vfilip
Capture_LDD is not supported yet. It should not be available in Components Library. Please use TimerUnit_LDD instead.
best regards
Vojtech Filip
Processor Expert Support Team
3,759 次查看
vfilip
best regards
Vojtech Filip
3,758 次查看
prajnithkumar
Can you please tell me when it will be available.
3,758 次查看
vfilip
the Capture_LDD should not be listed in component Library - it is a bug in current version. It should be fixed for next release.
Regarding Capture_LDD - I have got info the this component should be published in beginning of Q4 (probably within CW V10.5)
best regards
Vojtech Filip
