TWR-MCF54418 Processor Expert?
2,640 次查看
rfeibert
We have CW V7.2, and want to use Processor Expert to help generate code for various peripherals such as I/O, interrrupts, uart, etc. However, when invoke PE, View, CPU PArameters Overview, the MCF5441x (MCF54418) is NOT in the list.
How can we use PE for the MCF5441x, is there a software upgrade?? I do PE, Update, Check PE Web for updates, but there are no new updates since last check. Can you please help? Thank You
2,432 次查看
ProcessorExpert
Senior Contributor III
unfortunatelly, there is currenlty no service-pack available for CodeWarriro V7.2 (Classic) and as far as I know that the publishing of service-pack with support of TWR-MCF54418 in Processor Expert for CodeWarriro V7.2 is scheduled for the Q4 of 2011.
However, the TWR-MCF54418 has been already supported in CodeWarrior V10.1 (Eclipse) and I think this version should provide the same job for you.
best regards
Vojtech Filip
Processor Expert Support Team
2,433 次查看
ProcessorExpert
best regards
Vojtech Filip
