PE S08QA4 TimerInt - Unexpected status of script
BenFan
Hello.
I have some strange problem with ProcessorExpert and TimerInt on HCS08QA4
When I add component to project I get this error message:
+TI1
  +INTERNAL ERROR: Unexpected status of script: Drivers\Common\GenReg8BitsInitInfo.prg, please contact Freescale support.
  +INTERNAL ERROR: Unexpected status of script: Drivers\Common\SetReg8.prg, please contact Freescale support.
  +INTERNAL ERROR: Unexpected status of script: Drivers\HCS08\TimerInt.tst, please contact Freescale support.
The problem only appears with RTIfree as periodic interrupt source.
I have disabled other components, repair/installed the CW 6.3 and also imported into CW 10.1 with the same error message.
Could someone give me some hints on how to make it work or fix it?
thnx,
Ben
ProcessorExpert
Senior Contributor III
please find the enclosed two hot-fix archives which fix this issue. Details how to install them and closer details about fix are in readme.txt in each archive.
best regards
Vojtech Filip
Processor Expert Support Team
ProcessorExpert
best regards
Vojtech Filip
