Processor Expert Vybrid DDR3 Init_DDR TXSNR error
McuG
We are trying to initialize the DDR3 module (and to verify our settings) using the Init_DDR module in Processor Expert (Vybrid). All values are filled from the DDR3 datasheet I get an error for the timing configuration , TXSNR field (while it is calculated as per JEDEC 8*txs). Is there a way of bypassing this error and generate the code ? Does anyone know the formula that is used inside PE for validation ?
McuG
Updated to DriverSuite_10.4.3_update.zip , and the problem was addressed (we were using DriverSuite_10.4_Install_into_Eclipse_3.7_4.2.zip initially, not aware of the update).
McuG
